Lovelace weather forecast shows wrong forecast using OWM?
HI,
Using the weather forecast cast in Lovelace on OWM doesn’t show the forecast in the next 5 days, but the next 5 available forecast data apparently. Buienradar (albeit with a sunny cloud during nighttime…) and Yahoo show correctly, as does my custom animated weather card:
not sure if regular HA shows it correctly since my weather components don’t show up anymore (maybe another issue?) , but the same component OWM in the animated variant shows fine:
17
Ow can this be changed, if possible, or is it a bug in the card/component?
comparing the dev-state shows an enormous amount of Objects:
so maybe there is a setting in the Owm component to change that, I am not aware of?
