When looking into Lovelace I found a post on Reddit about using gifs as a background. Sadly a 1080p gif tends to be quite big in file size. So here is an option that allows you to use an mp4.
This card uses position absolute to load itself in the background. And I use an Iframe to then set the content of the absolute div. This is due to the fact that using the directly would sometimes not load, even though it was on mute, loop and autoplay.
There are also still some cinemagraphs missing for some weather conditions.
How to install:
Copy “weatherbg-card.js” and the folder “weather-animations” into your /www/
Add the card to your resources in the ui-lovelace.yaml
- url: /local/weatherbg-card.js
type: module
Load the card as the last card in your view and hand it a weather object
- type: "custom:weatherbg-card"
weather: weather.dark_sky
#NO CARDS AFTER THIS THEY WILL NOT BE SHOWN
You can change the videos to whatever you like by editing the HTML files in “weather-animations”.
By default, the video has a 20% opacity black overlay. This can be adjusted in the main .js file by changing the background of “.bg-wrap:before”
- title: Example
background:
theme:
cards:
- type: weather-forecast
entity: weather.dark_sky
url: /local/custom_ui/weather-animations/cloud.html
I am still looking on how to improve this or even creating a PR for Polymer.
firstof9
(firstof9)
October 13, 2018, 10:45pm
2
Using the code you passed me I did this:
The choppiness is from the capture program, it’s actually smooth.
matisaul
(Matias Saul)
October 14, 2018, 1:09am
3
Holy sh*t … That’s amazing!!! Could you share how did you do that??
Thanks @perdemot for this nice card!!
callifo
(Callifo)
October 14, 2018, 1:18am
4
That’s amazing, what impact does it have on the client, is this still usable remotely?
firstof9
(firstof9)
October 14, 2018, 3:28am
5
FYI @perdemot I used this bit in the HTML to autoplay and loop the video:
<video autoplay muted loop>
<source src="myvideoloop.mp4" type="video/mp4">
</video>
firstof9
(firstof9)
October 14, 2018, 3:33am
6
Runs smooth as silk when I browse it from my phone
Using the same in my iframe setup, but it doens’t properly work on some devices. Might be my adblock. Currently looking into it.
firstof9
(firstof9)
October 14, 2018, 3:20pm
8
True, I only have tested it in Chrome on my desktop and cell phone.
I did have to modify the iframe a touch too:
<iframe class="bg-iframe" scrolling="no" src="${config.url}"/>
with a small mod to the css as well:
.bg-wrap{
position: absolute;
right: 0;
bottom: 0;
min-width: 100vw;
min-height: 100vh;
top:-117px;
z-index: -1;
Trace-star
(Trace Star)
October 24, 2018, 8:26am
9
I want to know how to change different gifs
this needs to be a built-in HA option on any screen. thats killer, well done!
maurizio53
(Maurizio Fabiani)
October 24, 2018, 10:31am
12
I set this in ui-lovelace.yaml:
- icon: mdi:weather-cloudy
title: Meteo2
cards:
weather: weather.meteo_darksky
And i have weather.meteo_darksky configured in this way:
entity: weather.meteo_darksky
In configuration.yaml i have:
weather:
- platform: darksky
api_key: !secret darksky_api_key
mode: daily
But in the front end i can see only the mp4 video and not the card.
Where am i wrong?
maurizio53
(Maurizio Fabiani)
October 24, 2018, 4:26pm
13
Anyone can help me in finding where i am wrong?
Is it easy to set it as background in a weather card?
maurizio53
(Maurizio Fabiani)
October 26, 2018, 11:59am
15
I cannot get the card over the background… i followed the instructions here, but i get only the mp4 background.
firstof9
(firstof9)
October 26, 2018, 1:44pm
16
What browser are you using?
firstof9
(firstof9)
October 26, 2018, 10:42pm
18
Can you post your whole lovelace.yaml ?
maurizio53
(Maurizio Fabiani)
October 27, 2018, 10:20am
19
type: module
title: Meteo2
cards:
firstof9
(firstof9)
October 27, 2018, 11:35am
20
So you don’t have a weather card set to display so, try something like this:
- type: custom:dark-sky-weather-card
entity_sun: sun.sun
entity_daily_summary: sensor.dark_sky_daily_summary
entity_current_conditions: sensor.dark_sky_icon
entity_humidity: sensor.dark_sky_humidity
entity_pressure: sensor.dark_sky_pressure
entity_temperature: sensor.dark_sky_temperature
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.dark_sky_wind_bearing
entity_wind_speed: sensor.dark_sky_wind_speed
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4
entity_forecast_icon_1: sensor.dark_sky_icon_1
entity_forecast_icon_2: sensor.dark_sky_icon_2
entity_forecast_icon_3: sensor.dark_sky_icon_3
entity_forecast_icon_4: sensor.dark_sky_icon_4
entity_forecast_icon_5: sensor.dark_sky_icon_5
maurizio53
(Maurizio Fabiani)
October 27, 2018, 12:23pm
21
Yes, i have it… forgot to quote…
title: Meteo
entity_weather: weather.meteo_darksky
entity_sun: sun.sun
entity_background: Beach.jpg
