That’s another card (without title) stacked below the windrose card.
Version 1.5.0 released.
Added support for Beaufort windspeed scale.
If you change the entities speed unit in HA, history data is not changed.
The windrose uses history data, so the card gets values with mixed unit types. This can cause errors in the browsers console.
hey is it possible to use 4 hall sensors for this card
i have wind directions from 4 hall sensors that can output 8 directions
You need to make a template sensor to combine the four hall sensors into a single direction sensor. Start a new topic for help with this.
