Lovelace wrong panels position, need to refresh page
Sometimes it can happen that when I open the Home Assistant dashboard, the panels are in the wrong order, but I am able to fix the issue by refreshing the page with F5. How can I permanently solve this problem? My Home Assistant is hosted on a Raspberry Pi 4, while in my room I use a monitor connected to a Raspberry Pi 3 with FullPageOS. Occasionally, everything is disorganized on startup, and I have to get lucky by refreshing the page after connecting a keyboard. Any help?
Does your dashboard consist of separate panels? The only guaranteed way to force them into a particular order is to put them into vertical or horizontal stacks (or a combination of both).
This is two vertical stacks with a horizontal stack or grid on each row.
I had marked your answer as the solution, but I am still having problems. Try to imagine that the right side of your dashboard ends up below the left side, making the page very tall and the right side empty.
I use the layout card to control this.
https://gbudjqkycm2w8lj7541a5eof2trzieco.ui.nabu.casa/hacs/repository/156434866
