I think I did it. Thanks
Regards.
are the temperature and humidity sensors defined?
O.K. Iāve copied wrong (eariler) configuration dataā¦
Now replaced with code from Septemberā¦
But not sure why I see the four triangles with !..
Checked the code, but could not find the reasonā¦
I think it would be quite helpful if you posted the lovelace code, and then the full name of all relevant entities.
Looks like simple reference errors.
Yes, anyway Iāve made further corrections - looks much betterā¦
But when the favorites icon is clicked - I see something like that.
So still something missedā¦
Indeed entity āinput_select.mi_air_purifier_3h_coverageā is not on the list of available entities.
So some code still missedā¦
First, update your configuration with the one from post 239. Is the latest one considering template. Also add just the input_select definition from my scripts to you config file.
Yes, my faultā¦ I missed some posts. Now corrected.
Still 1 more question - when I click the āheartā sign the values are changing from 1.0 to 10.0 or moreā¦
But nothing is changing below - i.e. square meters are the same always 2-4m2.
somehow Iāve exactly the same issue, squares are not changing, it was working fine before
i tried to troubleshoot but found nothing
I think there is something with the automation/scripts.
I fixed it few weeks ago but unfortunately my HA crashed yesterday so I had to reconfigured again almost everything because my latest saved backup was from 2 month ago.
I had to do a lot of work to update HA to the latest config (templates in config etc,missing entities, addons) and now solved almost everything except purifier that is currently not working.
Check that you have:
- configuration
# Mi Air Purifier 3H #
input_select:
mi_air_purifier_3h_coverage:
options:
- 2-4 mĀ²
- 5-9 mĀ²
- 7-12 mĀ²
- 12-22 mĀ²
- 14-24 mĀ²
- 14-25 mĀ²
- 16-27 mĀ²
- 17-30 mĀ²
- 18-32 mĀ²
- 19-33 mĀ²
- 20-34 mĀ²
- 22-38 mĀ²
- 23-40 mĀ²
- 26-45 mĀ²
- 28-49 mĀ²
icon: mdi:texture-box
- automation
- id: '1234567891014'
alias: AP04 - Air Purifier favorite level to coverage
description: ''
- platform: state
entity_id: number.mi_air_purifier_3h_favorite_level
condition: []
- service: input_select.set_options
entity_id: input_select.mi_air_purifier_3h_coverage
options: '{% if states("number.mi_air_purifier_3h_favorite_level") | int ==
0 -%} 2-4 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level") |
int == 1 -%} 5-9 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 2 -%} 7-12 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 3 -%} 12-22 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 4 -%} 14-24 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 5 -%} 14-25 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 6 -%} 16-27 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 7 -%} 17-30 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 8 -%} 18-32 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 9 -%} 19-33 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 10 -%} 20-34 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 11 -%} 22-38 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 12 -%} 23-40 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 13 -%} 26-45 mĀ² {%- elif states("number.mi_air_purifier_3h_favorite_level")
| int == 14 -%} 28-49 mĀ² {%- else -%} {%- endif %}'
mode: single
this was it, Iāve simply overlooked the fact that I was referring to the old combination (entity + attribute)
description: ''
- entity_id: fan.mi_air_purifier_3h
attribute: favorite_level
platform: state
condition: []
- data:
option: '{% if is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
0) -%} 2-4 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
1) -%} 5-9 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
2) -%} 7-12 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
3) -%} 12-22 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
4) -%} 14-24 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
5) -%} 14-25 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
6) -%} 16-27 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
7) -%} 17-30 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
8) -%} 18-32 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
9) -%} 19-33 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
10) -%} 20-34 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
11) -%} 22-38 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
12) -%} 23-40 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
13) -%} 26-45 mĀ² {%- elif is_state_attr(''fan.mi_air_purifier_3h'',''favorite_level'',
14) -%} 28-49 mĀ² {%- else -%} {%- endif %}'
service: input_select.select_option
thank you and sorry, I should have spot that
O.K. I corrected that - now better. Square meters are changing alsoā¦
However there is still 1 small issueā¦ When I open the card, the value is shown without point (i.e. 13).
But when I start changing that value (with + or -) it is shown with point (ex. 14.0).
See pictures what I meanā¦
That has something to do with the integration, when they introduced the number entity.
It should be fairly easy to never show decimals. I just havenāt been bothered to do it yet.
If you wait more time it will change it back to integer. donāt know at this moment how to get rid of the point.
I would probably create a template sensor where I forced it to round it, and use that instead.
That and of course create a bug report for the Miio integration, so they can fix the original issue.
Guys sorry if itās a stupid question, but i am a newbie
I have added my purifier using the Miio integration, copied every single line from the Dec 20 post, apart from the line where it states how to connect, but buttons do not work
Did i do anything wrong?
It still takes me a long time to update the sensors ā¦ minutes
variable|float|round|int
Should be seconds. You are using the official integration?
