I’ve checked the post several times, but I feel like I am missing some information
Right now I have the Purifier added and working with the default integration, what I am missing tough, is the mode entity, but it is necessary because it allows me to change mode through automation
Since the Purifier is already added, I just have to copy your config and paste it in my system right?
Guys, I am having a 30 minute update for PM2.5 în idle if nothing important is happening. And this I think is related to how the Purifier is sending the data.
Understand now you point. Thought you are referring to the value update we discussed few weeks ago. Indeed the pm2.5 update time is around 30 minutes. I think this is related either to the way integration is implemented or to the way Purifier is communicating. Worth investigating.
I don’t know where the issues is. In Mi home application the update is faster so it communicate more with the cloud or the app is asking for more.
However this is not the case for the Miio integration. In my case the update is exactly at 30 minutes with shorter interval if high increase detected.
As you can see in my case the values are typically low so my purifier is almost off all the time. Using the automations to wake it up when quick increase of pm2.5 is ok most of the time. Where there are delays is when changing the speed according to the pm2.5 reported values.
As I can see also on your picture, when the levels are lower than 20 the reporting interval is 30 minutes.
BTW mine is/was registered on European server, while all my other Xioami devices are on China. Where is/was yours?
