🪫 Low Battery Notifications & Actions
FAQ - How to create a button helper
  1. Go to Settings / Devices & Services / click on the “Helpers” tab / click “+ CREATE HELPER” and select “Button”.
  2. Enter in the name you would like to call the button helper and an icon if you like. Then click “Create”.
    3
You successfully created a button helper :tada: that you can now use it in the automation and include it into a dashboard. When you click on it, the automation will run and check your batteries to then notify you as per your automation settings.
Enjoy
Blacky :grinning:
Back to FAQ: Click Here
