Made a blueprint that scans all devices for any with battery % below a threshold then sends a notify message warning at a set time each day.
blueprint:
name: Low Battery Alert
description: >
Sends a notification at a chosen time if any battery sensors are below
a configurable threshold. Checks all `battery` device-class sensors and
reports the offending ones. Works with any notify service (mobile app,
Telegram, Pushover, etc.).
domain: automation
author: ""
homeassistant:
min_version: "2021.12.0"
input:
alert_time:
description: Time of day to check battery levels.
default: "18:30:00"
selector:
time: {}
battery_threshold:
name: Battery threshold (%)
description: Alert when a battery sensor falls below this percentage.
default: 5
selector:
number:
min: 1
max: 50
step: 1
unit_of_measurement: "%"
mode: slider
notify_target:
description: >
The notify service to call, e.g. `notify.mobile_app_my_phone` or
`notify.all_devices`. Must be a valid service under the `notify` domain.
selector:
select:
custom_value: true
options: []
variables:
threshold: !input battery_threshold
triggers:
- trigger: time
at: !input alert_time
conditions:
- condition: template
value_template: >
{{ states.sensor
| selectattr('attributes.device_class', 'defined')
| selectattr('attributes.device_class', 'eq', 'battery')
| selectattr('state', 'is_number')
| map(attribute='state')
| map('float')
| select('lt', threshold)
| list
| count > 0 }}
actions:
- action: !input notify_target
title: "🪫 Low Battery Alert"
message: >
The following devices are below {{ threshold }}%:
{% for sensor in states.sensor
if sensor.state | float < threshold %}
• {{ sensor.name }}: {{ sensor.state }}%
{% endfor %}
mode: single
