This is the full config:
mqtt:
host: 192.168.1.2
user: XXX
password: XXX
detectors:
coral:
type: edgetpu
device: pci:0
birdseye:
enabled: False
quality: 8
mode: continuous
detect:
width: 1280
height: 720
fps: 6
enabled: True
stationary:
interval: 0
threshold: 50
record:
enabled: True
retain:
days: 1
mode: all
events:
pre_capture: 1
post_capture: 1
objects:
- person
- cat
retain:
default: 1
mode: active_objects
snapshots:
enabled: True
clean_copy: True
timestamp: False
bounding_box: True
crop: False
retain:
default: 2
objects:
person: 3
ffmpeg:
#hwaccel_args: preset-vaapi
input_args: -rtsp_transport tcp
output_args:
record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
go2rtc:
streams:
front_yard:
- rtsp://XXX:[email protected]:554/Streaming/Channels/101
main_yard:
back_yard:
side_yard:
objects:
filters:
person:
min_area: 500
max_area: 50000000
min_score: 0.5
threshold: 0.7
motion:
threshold: 25
contour_area: 30
delta_alpha: 0.2
frame_alpha: 0.2
frame_height: 50
#improve_contrast: True
cameras:
front_yard:
ffmpeg:
inputs:
- path: rtsp://XXX:[email protected]:554/Streaming/Channels/101
roles:
- record
- path: rtsp://XXX:[email protected]:554/Streaming/Channels/102
roles:
- detect
objects:
track:
- person
- cat
ui:
order: 0
zones:
front_yard_street:
coordinates: 279,0,188,80,72,233,0,356,0,453,65,362,195,252,364,127,582,0
objects:
- person
front_yard_far:
coordinates: 171,311,52,415,21,632,146,687
objects:
- person
- cat
front_yard_mid:
coordinates: 338,720,397,175,162,315,139,681
objects:
- person
- cat
front_yard_near:
coordinates: 1280,720,1280,0,757,0,386,176,327,720
objects:
- person
- cat
motion:
mask:
- 240,0,0,0,0,335,61,237,145,114
main_yard:
ffmpeg:
inputs:
roles:
- record
roles:
- detect
objects:
track:
- person
- cat
ui:
order: 1
zones:
main_yard_far:
coordinates: 651,127,422,80,164,166,194,304
objects:
- person
- cat
main_yard_near:
coordinates: 977,231,1280,365,1280,720,369,720,190,290,647,125
objects:
- person
- cat
motion:
mask:
- 95,0,562,0,572,80,417,57,123,153
back_yard:
ffmpeg:
inputs:
roles:
- record
roles:
- detect
objects:
track:
- person
- cat
ui:
order: 2
zones:
back_yard_outside:
coordinates: 566,229,1226,720,1280,720,1280,336,674,0,435,0,239,0
objects:
- person
- cat
back_yard_far:
coordinates: 200,312,467,206,326,94,155,143
objects:
- person
- cat
back_yard_mid:
coordinates: 286,549,199,310,458,202,687,381
objects:
- person
- cat
back_yard_near:
coordinates: 675,375,1105,720,360,720,269,543
objects:
- person
- cat
filters:
person:
min_area: 500
max_area: 5000000
min_score: 0.5
threshold: 0.7
motion:
mask:
- 1280,0,1280,192,855,0
side_yard:
ffmpeg:
inputs:
roles:
- record
roles:
- detect
objects:
track:
- person
- cat
ui:
order: 3
zones:
side_yard_far:
coordinates: 123,511,285,259,110,259,21,378
objects:
- person
- cat
side_yard_mid:
coordinates: 583,283,330,673,118,505,273,258
objects:
- person
- cat
side_yard_near:
coordinates: 534,720,1019,720,1151,329,565,277,321,672
objects:
- person
- cat
motion:
mask:
- 0,0,311,0,99,255,33,339,0,297
Also, “laggs” might not have been the best description I gave before. I’m just watching cats walking around on the cameras and they move in frames, which I feel is due to the stream in HA being low FPS.
