Low-pass filter on binary sensor?
I have a binary sensor that gives me an on/off state of a device. I do get 0/1 values from a helper.
The device has a warm-up and cool-down phase that perfectly matches a typical exponential low-pass filter. I want to get a value of the current warm-up state.
The on-cycle may be shorter or longer than shown here, so it may not reach 0.8 before cooling off again. Or it may be switched off after a long run and quickly on again, keeping the warm-up-value high. So the warm-up does not necessarily start at zero but at the value to what the “off” state cooled down the curve before.
That looks like two problems to me:
  1. the sensor value is not time dependent and changes only when a change occurs. It is “still on” but I cannot integrate on the value. After switching “on”, the low-pass filtered sensor switches to 0.05 and sits there until the device goes off again. I would have to link this to the “time sitting in this state”.
  2. the “window size” and “time constant” parameters are quite vague. They might get any arbitrary value and I still cannot guess how this will affect the output.
The idea is to get the curve from zero to >0,99 after 20 minutes (or seconds).
If I can solve problem 1, would I have to set Window-Size=1, time-constant = 20 to get a “20 time-element” wide warm-up curve?
Could I use a different approach to calculate the red curve from the blue one, or at least one that is similar enough?
I could calculate this with an electronic RC circuit, but this one confuses me. And other than in a spreadsheet I cannot just try out some values and watch the result. I always have to measure and wait through a real cycle to collect real values.
Any ideas?
You only have the binary sensor and you want another sensor to calculate the red line?
Create a simulated input sensor to accelerate your experiments.
The filter integration will not work for this. As you discovered, it only updates when the state of the input sensor changes (so once at “on” and once at “off”). You would have the same issue with the compensation, integral or derivative integrations. It’s how Home Assistant works. State changes drive integration state changes.
You could use a triggered template sensor. Trigger every x seconds and update your exponential equation based on the binary sensor state.
If you have the “electronic RC circuit” equation I can help with the template.
