Lower temperature when a window opens
Description
When the window opens, lower the temperature of a climate entity instead of changing its HVAC mode.
It stores the original state of the climate entity in a Scene before reducing the temperature so it can restore it after the window is closed.
Ensure to input a unique scene name to avoid overriding an existing one.
I created this blueprint because I have a Danfoss Ally (Zigbee), and this TRV has only one HVAC mode: "heat".
Tested devices
  • Danfoss Ally TRV integrated in HASS via Zigbee2Mqtt
The blueprint
blueprint:
    name: Lower temperature when a window opens
    description: Lower the HVAC temperature when a window opens. Restart the previous temperature when it closes.
    domain: automation
    input:
        window_entity:
            description: The window sensor that controls the climate entity. If you have more window sensors please make a group sensor.
            selector:
                entity:
                    domain: binary_sensor
                    device_class: window
                    multiple: false
        climate_target:
            description: The climate entity that is controlled by the window sensor
            selector:
                entity:
                    domain: climate
                    multiple: false
        minimum_open_time:
            description: Time in seconds to wait until the automation is triggered
            name: Minimum open time
            default: 10
            selector:
                number:
                    min: 0.0
                    max: 59.0
                    unit_of_measurement: seconds
                    step: 1.0
                    mode: slider
        off_temperature:
            description: Temperature to set when the window is open
            name: Open window temperature
            default: 5
            selector:
                number:
                    min: 0.0
                    max: 21.0
                    unit_of_measurement: degrees
                    step: 1.0
                    mode: slider
        scene_id:
            name: Scene name to store the initial climate state
            selector:
                text:
                    multiline: false
mode: single
variables:
    scene_id: !input scene_id
  - platform: state
    entity_id: !input window_entity
    to: "on"
    for: !input minimum_open_time
  - service: scene.create
      snapshot_entities: !input climate_target
  - service: climate.set_temperature
      temperature: !input off_temperature
      entity_id: !input climate_target
  - wait_for_trigger:
      - platform: state
        to: "off"
  - service: scene.turn_on
      entity_id: "scene.{{ scene_id }}"
Thanks @dzegarra for Your work.
Blueprint work as expected with Z-wave Danfoss TRV.
