(LOXONE) need to acces homeassistant sensor from network without token
Hi all !
i’m new in the hassio game, with a loxone miniserver.
i would like to keep using loxone in frontend, and access info from hassio into my loxone config…
i already do this with my bose soundtouch system (read the volume and status from the url of the bose system) !!!
is it possible with the last version of hassio, to simply authorize an url api to show sensor without token or authentification method, from a local ip, or with a password send in the url (example : http://admin:PASSWORD@hassioip:8123/api/states/sensor.person.admin)
any help would be apprecied !!
PS : i can’t use bearer token in loxone config for this… i can only read data from a url !
Thanks :smiley:
up :sweat_smile:
Hi Elmattt,
This might help you:
