I do have a strange problem.
I had a LSC ledstrip before, paired by Tuya app working fine in HA with Tuya integration.
I changed wit a new LSC LERD strip, get it connected to Tuya and it is controlable in HA.
So far so good.
I try to automate something in NodeRED. With the earlier LEDstring it is working fine.
The new one will not switch on after trigger by Action node.
The app and HA shows that the LED string is switching on after Nodered action button, but it actual don’t do switch on.
If I do switch it on by hand using HA or Tuya app it is going on.
If it is on I can switch it off by Nodered, but not getting it switched on again.
The most strange pasrt is that sometimes emidiately after deploying it is working once.(Not always). After switching it off by NR it won’t work switching on anymore
working node switching off:
Not working node switching on:
After injection the node itself also shows it is switched on as also in HA itself(while not):
I do use the latest node-red-contrib-home-assistant-websocket pallet (0.74.2)
Any Ideas?
EDIT:
I did find a work around:
First a node to switch on wait a second, change color:
