First go at tuya-cloudcutter. Flashed esphome on my device but can’t get it work properly. The challenge (for me) is the separate pins for on and off .
I’ve tried to solve it with the following code but the switches behave eratically. For example switching one relay on works but then shortly after switches off again by itself.
Any help much appreciated.
I base my yaml of of the following info: https://github.com/tuya-cloudcutter/tuya-cloudcutter.github.io/blob/4934b68d31df1b00eb7e73ab4811919f50d5de20/devices/lsc-3004200-wifi-outdoor-dual-socket.json
esphome:
bk72xx:
board: generic-bk7231t-qfn32-tuya
logger:
web_server:
captive_portal:
mdns:
api:
password: ""
ota:
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
text_sensor:
- platform: libretiny
version:
binary_sensor:
- platform: gpio
pin:
number: P7
inverted: true
mode: INPUT_PULLUP
switch:
turn_on_action:
- switch.turn_off: switch_1_off
- switch.turn_on: switch_1_on
- logger.log: "Switch Turned On!"
- light.turn_on: stat_led
turn_off_action:
- switch.turn_off: switch_1_on
- switch.turn_on: switch_1_off
- logger.log: "Switch Turned Off!"
- light.turn_off: stat_led
turn_on_action:
- switch.turn_off: switch_2_off
- switch.turn_on: switch_2_on
turn_off_action:
- switch.turn_off: switch_2_on
- switch.turn_on: switch_2_off
- platform: gpio
pin: P14
- platform: gpio
pin: P9
- platform: gpio
pin: P26
- platform: gpio
pin: P8
# - platform: gpio
# id: switch_all
# name: Relay 1&2
# pin: P7
# on_turn_on:
# - switch.turn_off: switch_1_off
# - switch.turn_on: switch_1_on
# - switch.turn_off: switch_2_off
# - switch.turn_on: switch_2_on
# - logger.log: "Switch Turned On!"
# - light.turn_on: stat_led
# on_turn_off:
# - switch.turn_on: switch_1_off
# - switch.turn_off: switch_1_on
# - switch.turn_on: switch_2_off
# - switch.turn_off: switch_2_on
# - logger.log: "Switch Turned Off!"
# - light.turn_off: stat_led
light:
- platform: status_led
pin:
number: P1
inverted: true
#status_led:
# pin:
# number: P1
# inverted: true
EBME2
(Ebme2)
September 30, 2023, 4:35pm
2
Are the relays not bistable relays that just require a pulse on a pin to switch on, and a pulse on another pin to switch off? The GitHub mentions a relay drive time of 60, not a 60ms pulse to switch on/off is it?
The relay will only switch on when the ‘off’ pin is off and the ‘on’ pin is on. That is as far as I’ve come.
I would not know how to go about just sending a pulse.
I’ve think that the relay crashes/reboots constantly as the uptime sensor I’ve added never reaches one minute.
RedEd
(RedEd)
December 2, 2023, 7:02pm
4
don’t know if you already got it fixed, but i just got mine up and running with the below code.
esphome:
friendly_name: Garden Spike 1
area: Terasse
bk72xx:
# Enable logging
logger:
web_server:
captive_portal:
mdns:
# Enable Home Assistant API
api:
encryption:
key: "<Your API KEY>"
ota:
password: "<Your OTA Password>"
wifi:
#manual_ip:
#static_ip: 192.168.1.100
#gateway: 192.168.1.1
#subnet: 255.255.255.0
ap:
ssid: "Garden Spike 1.fb"
password: "<YourPassword>"
button:
- platform: restart
debug:
update_interval: 30s
text_sensor:
- platform: debug
reset_reason:
version:
- platform: wifi_info
ip_address:
- platform: uptime
binary_sensor:
- platform: gpio
pin:
number: P7
inverted: true
mode: INPUT_PULLUP
lambda: |-
if (id(relay1).state || id(relay2).state) {
return true;
else {
return false;
on_state:
if:
condition:
- binary_sensor.is_on: relay_state
then:
else:
switch:
- platform: gpio
pin: P14
- platform: gpio
pin: P9
- platform: gpio
pin: P26
- platform: gpio
pin: P8
turn_on_action:
- delay: 0.1s
- switch.template.publish:
state: true
turn_off_action:
- delay: 0.1s
state: false
turn_on_action:
- delay: 0.1s
state: true
turn_off_action:
- delay: 0.1s
state: false
light:
- platform: binary
output: light_output
output:
- id: light_output
platform: gpio
pin:
number: P1
inverted: true
I also changed the LED to be only on if any of the relays is switched on.
Else it will be turned off.
So it’s a bit more like the original behaviour
And one more thing, that i just made:
I wanted the button on the top to be the main switch, so i could turn both relays on in and off.
There was a little issue with it, because if you just let them turn on and off in a sequence it will sound a bit odd, so i made it run parallel.
If anybody wants this, just add this 2 blocks in and delete the old binary_sensor section.
script:
- id: switches_on
mode: parallel
then:
- switch.turn_on: relay1
- switch.turn_on: relay2
- id: switches_off
mode: parallel
then:
- switch.turn_off: relay1
- switch.turn_off: relay2
binary_sensor:
- platform: gpio
pin:
number: P7
inverted: true
mode: INPUT_PULLUP
on_release:
if:
condition:
- binary_sensor.is_off: relay_state
then:
- script.execute: switches_on
else:
- script.execute: switches_off
lambda: |-
return true;
else {
return false;
on_state:
if:
condition:
then:
else:
