LSC Smart Connect [ACTION]
Hi all
Recently i was walking trough the “Action” store in Holland and saw a set of ‘smart products’ called LCS Smart Connect. This smart products consist of different smart lights, motion sensors and switches.
It caught my attention because of its very reasonable price tag.
  1. Brief description of the device or service.
    Smart lights, switches and sensors by a new brand sold at Action (Holland).
  2. Link to the provider or manufacturer’s product or service page.
    https://www.action.com/nl-nl/brand/lsc-smart-connect/
  3. Link to the service or device’s API, along with information as to whether it is public or requires an account or key. (This is extremely important because without a published API, integration of any device or service will be difficult if not impossible!)
    Dont know if this is the right one, but:
    https://github.com/codetheweb/tuyapi
  4. Any other relevant information including examples or GitHub repositories related to the device or service.
    Found it from this page:
    https://community.openhab.org/t/lsc-smart-connect-tuya-binding/81093
This products seem of good quality. (Judged only on packaging and look & feel).
Some of them you can flash with tasmota, but not all of them. My 2 ‘smart plaffonieres’ don’ t work with the official tuya api ( except the scenes) or the local tuya api (and I have the local key)
I bought the power plug and a rgb ligth (E14 version) from LSC and flashed them via Tuya convert over the air:
Then I flashed the Tasmota firmware via ota.
For the RGB light you will need the dev version of Tasmota. The power plug works with the master version, almost the same as a Sonof device.
Not al LSC Smart devices work with with a ESP8266/8285 so not all flashable with Tasmota.
I do have the rgbw led strip working with esphome.
I have only added a few buttons of the remote control yet
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "SSID"
  password: "PASSWORD"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
remote_receiver:
  pin:
    number: 0
    inverted: true
  dump: all
#  filter: 50us
output:
  - platform: esp8266_pwm
    pin: 4
    frequency: 1000 Hz
    pin: 14
    frequency: 1000 Hz
    pin: 12
    frequency: 1000 Hz
    pin: 13
    frequency: 1000 Hz
light:
  - platform: rgbw
    name: "Washok Led Strip"
    red: pwm_rood
    green: pwm_groen
    blue: pwm_blauw
    white: pwm_wit
    effects:
      - strobe:
          colors:
            - state: true
              brightness: 100%
              red: 100%
              green: 0%
              blue: 0%
              white: 0%
              duration: 1000ms
            - state: true
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              white: 0%
              duration: 1000ms
            - state: true
              brightness: 100%
              red: 0%
              green: 0%
              blue: 100%
              white: 0%
              duration: 1000ms
binary_sensor:
  - platform: remote_receiver
    internal: true
    nec:
      address: 0x00F7
      command: 0xC03F
    on_press:
      then:
        light.turn_on:
    internal: true
    nec:
      address: 0x00F7
      command: 0x40BF
    on_press:
      - then:
         light.turn_off:
    internal: true
    nec:
      address: 0x00F7
      command: 0xE01F
    on_press:
      - then:
         light.turn_on:
           brightness: 100%
           red: 0%
           green: 0%
           blue: 0%
           white: 100%
    internal: true
    nec:
      address: 0x00F7
      command: 0x609F
    on_press:
      - then:
         light.turn_on:
           brightness: 100%
           red: 0%
           green: 0%
           blue: 100%
           white: 0%
    internal: true
    nec:
      address: 0x00F7
      command: 0x20DF
    on_press:
      - then:
         light.turn_on:
           brightness: 100%
           red: 100%
           green: 0%
           blue: 0%
           white: 0%
    internal: true
    nec:
      address: 0x00F7
      command: 0xA05F
    on_press:
      - then:
         light.turn_on:
           brightness: 100%
           red: 0%
           green: 100%
           blue: 0%
           white: 0%
    internal: true
    nec:
      address: 0x00F7
      command: 0xF00F
    on_press:
      - then:
        - light.turn_on:
            effect: strobe
And this is for the filament light
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "SSID"
# Enable logging
logger:
api:
ota:
light:
  - platform: cwww
    cold_white: output_component1
    warm_white: output_component2
    cold_white_color_temperature: 3500 K
    warm_white_color_temperature: 2000 K
#    default_transition_length: 5s
output:
    pin: 14
    pin: 12
The sirene and the ceiling light have a different chip so it will not work but the work if you make a scene in the tuya app
This is my code for the plug:
substitutions:
  devicename: LSC Plug
esphome:
  platform: ESP8266
  board: esp01_1m
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
      inverted: true
    name: "$devicename Power Button"
    internal: true
    on_press:
      - switch.toggle: relay
  - platform: status
switch:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: true
  - platform: gpio
    icon: "mdi:power-plug"
    pin: GPIO12
    on_turn_on:
      - switch.turn_on: led
    on_turn_off:
      - switch.turn_off: led
wifi:
  ssid: !secret ssid
  password: !secret password
# Enable logging
logger:
api:
  password: !secret api_ota_pwd
ota:
Where did you found the pin to use for LSC lights?
I want to flash the GU10 led light
Thanks!
I flashed the gu10 using the new tuya- convert.
Could you post your Esphome yaml?
I’m using Tasmota on it (6.6.0.18)
Somebody already flashed the door contact sensor ?door sensor
is there a way to use the other color buttons on the AB, and/or the “smooth” action button ?
Yes but you need to find the correct nec commands for the other buttons and then ass them
Where did you get this tasmota release?
All I can find is release 6.6.0
You can try http://thehackbox.org/tasmota/ for the latest
@gijsje How do you get all the right nec addresses and commands for the remote?
Open the log and push the button and look at the code
This is my LSC Smart LED Light Strip 970750 ESPHome script. It includes all buttons on the remote control.
Kudos to @gijsje
Thanks saves me some work :slight_smile:
