Any experience/photos where to start first to take the bulb apart?
Sure.
Start by prying off the plastic dome. This is glued on around the edges. Be careful not to nick the LED PCB or a use a plastic prying tool This is the second hardest part. Then you will have this:
Then comes the hardest part which I failed at. Removing the main board & TUYA-module without removing the wire at the socket (I think it was the black one that had a flimsy connection). It came loose so I had to remove the socket from the housing aswell to re-attach it…
Since the entire module was out of the housing, this part is a bit easier ofcourse; so the wire coming loose had an upside Desolder the TUYA-module from the base board, solder on some wire so you can flash it:
Flash it, reattach everything, clean up any rough edges. I only left one scratch on it because I started with a knife… But the end result is prety clean:
Thanks!! Once shops open again, hope to get one and try as well.
Found out that exactly the same goes for the E14 Kruidvat Smart lamp, its a 1:1
Great add!
Hey guys,
I’m pretty new with home assistant and I’m trying to figure out how I can connect my LSC Smart lights to Home Assistant.
Reading all this is a bit overwhelming and I’m not sure if I am up to the task.
First, what I was wondering, how can it be that within Google Home you can connect the LSC Smart Connect configured lights to Google Home from login with Tuya/Smartlife with your LSC account details, while that doesn’t work on the Tuya website or on the tuya integration on Home Assistant?
Second, if this whole flashing is needed to connect them to Home Assistant with the Tuya integration, how can I find out if they are able to be flashed without risking breaking my lights?
I have 1 RGB E27 and 2 RGB GU10 from LSC Smart Connect that I would like to connect to Home Assistant.
Same issues here. It’s a great looking lamp, but unusable with the noise it produces
Topic kick today I finally managed to get to the local Action. I find out that they sell some LCS outdoor lamp now . I bought 3 of them, and hoped that it’s possible to flash these to ESPhome . Are there some user who did this ? (Or maybe failed , because I read a lot that they changed to other chips )
I would try opening it up to identify the chip used. If it’s not an Espressif chip I would not get my hopes up for a software flash. And even if it is an Espressif chip, lots of later LSC hardware already shipped to the stores with stock firmware that contained patches against tuya-convert, so for new products I would suspect exactly the same.
Could anyone point me to the right direction?
I have been able to figure out the local-key and the device ID of my smart bulb (E27 RBG 806lm).
Now, I tried to connect them to HA by using GitHub - stast1/localtuya localtuya.
I tried both by using the GUI and editing my main config file, but both did not work.
Mind you, I figured out the local-key and device ID on a separate network, so I am not sure what IP address to use.
I tried by using a local IP what my network would use (192.168.1.10) but that did not work, and when using the smart life app, I saw the bulb got a public IP address assigned, so I just tried that but that did not seem to matter.
No matter what I do I get
"An unknown error occurred. See log for details.:
Upon checking the logs:
File "/config/custom_components/localtuya/common.py", line 139, in _make_connection
self._interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 637, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1025, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1010, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 924, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 496, in sock_connect
return await fut
File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 528, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
TimeoutError: [Errno 110] Connect call failed ('192.168.1.10', 6668)
So my main question is:
after figuring out the local-key and the device ID of my smart bulb (E27 RBG 806lm), what IP address do I use to connect with localtuya?
Hi all!
I recently started with HA and I’m playing around with it.
Now I bought 3 GU10 LSC lights from the well known store and was wondering if I can still flash them.
I’ve read a lot in this topic but as it is all a bit old I don’t know if the lights I bought are flashable these days.
Or is there another way to connect my lights with HA as I was able to add the lights in Google home?
Hope anyone can help me with this.
Hi Kevin, did you try to flash them? I would like to know too They are on sale right now and i’m quite interested in the outdoor ledstrip. But i need to control about 5 of them so i’m not sure if i should buy them… On the other hand, they are controlable through the app, just would be nice to add them to HA. Maybe @gijsje could chime in?!
Hi Kevin,
I have soms GU10 bulbs working bit with an external driver. In this topic there is somewhere a post with the discription.
Kind regards,
Thetmar
I did not try to flash them, as I don’t know yet how to begin.
Will dive in to this hopefully this week.
I checked things on the internet and it seems I cannot find a configuration for my GU10 lights on (Light Bulbs by Socket).
Only the RGBW version and I have the White version.
Anybody that can assist with this?
Well, i tried to connect the ledstrip with the app, but it failed to connect. Tried for an hour and then gave up. Drove me nuts
Do they have power metering?
Nope, only on/off functionality.
Hi all,
I notice this discussion has been silent for a while, but I have a LSC E27 RGB light and a few questions about it.
So I have already connected to the app and then, through the Tuya cloud platform, to the local Tuya integration. My lamp is now connected to hass, but don’t know which settings I need to be able to control the color etc.
Could someone give me some directions?
Gu10 with bekon chip:
bk7231n
(my lights had tuya firmware version 1.3.21)
flashed with tuya cloudcutter
esphome:
friendly_name: ${friendly_name}
substitutions:
friendly_name: lsc Gu10 1
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "oB6xQEP99BP33KPdqN285OXg4QVUpkukjjDXzlqnMJQ="
ota:
password: "298901f489dc0d339a54e9347ceabca3"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${friendly_name} Fallback Hotspot"
captive_portal:
bk72xx:
board: generic-bk7231n-qfn32-tuya
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
update_interval: 60s
- platform: uptime
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
text_sensor:
name: Uptime Human Readable
icon: mdi:clock-start
- platform: wifi_info
ip_address:
entity_category: diagnostic
binary_sensor:
- platform: status
button:
- platform: restart
bp5758d:
data_pin: P26
clock_pin: P24
output:
- platform: bp5758d
channel: 3
- platform: bp5758d
channel: 1
- platform: bp5758d
channel: 2
- platform: bp5758d
channel: 4
- platform: bp5758d
channel: 5
light:
- platform: rgbww
restore_mode: ALWAYS_OFF
red: output_red
green: output_green
blue: output_blue
cold_white: output_cold_white
warm_white: output_warm_white
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 2700 K
color_interlock: true
constant_brightness: true
effects:
- random:
transition_length: 30s
update_interval: 30s
- random:
transition_length: 4s
update_interval: 5s
- strobe:
- flicker:
alpha: 50% #The percentage that the last color value should affect the light. More or less the “forget-factor” of an exponential moving average. Defaults to 95%.
intensity: 50% #The intensity of the flickering, basically the maximum amplitude of the random offsets. Defaults to 1.5%.
- lambda:
update_interval: 1s
lambda: |-
static int state = 0;
auto call = id(the_light).turn_on();
// Transtion of 1000ms = 1s
call.set_transition_length(1000);
if (state == 0) {
call.set_brightness(1.0);
} else {
call.set_brightness(0.01);
call.perform();
state += 1;
if (state == 2)
state = 0;
## Blink the light if we aren't connected to WiFi.
## Uncomment below
#interval:
#- interval: 500ms
# then:
# - if:
# condition:
# not:
# wifi.connected:
# then:
# - light.turn_on:
# id: the_light
# brightness: 50%
# transition_length: 0s
# - delay: 250ms
# - light.turn_off:
# id: the_light
# transition_length: 250ms
