LTS Integration
Is there anyway that i can integrate my LTS nvr camera system into HA?
Do the cameras or NVR support ONVIF?
Or do you have still image and/or streaming (rtsp) URLs for the cameras?
@tom_l
i thing i have the rtsp. I will try to get it set up tonight… Thanks for the links!!
I was able to set this up using ONVIF. Tried to get RTSP to work but could not figure that out. I had to go into the labyrinth of the LTS Software and activate ONVIF and create a new user/pw on the LTS system specifically for this but that was easy enough. It was finding the right setting in the truly complex UI in LTS that was the hard part. Once ONVIF was enabled, the cameras were discoverable by HA.
