Sun Jul 07 2019 18:01:29 GMT+0200 (hora de verano de Europa central)
Can not load data from luftdaten.info
I’ve read the documentation again, checked the configuration file, but I can’t find the error.
What am I doing wrong?
probably nothing, Luftdaten has its peculiarities, as far as I read the comments on the community forum.
Maybe it will come to life in a while. I am struggling with the same setup. You can check if your selected station has the monitored conditions available in the legend:
by clicking on the box with the arrow and see what comes up on your station.
other than that, I am afraid there’s not much you can do.
update
as I have just found myself, you can see and try (you probably should, as it is the new way of setting up HA…) if you can configure the station via the integrations page under configuration.
I’ve done so myself just now for a few stations providing different readings, and some of these show up, some of them don’t:
using the integration, you only need to have luftdaten: in your configuration files, and have the integration set the specific stations.
In my case, I have first eliminated Integration. In a second step, I reactivated the Integration and entered the station code.
It is working correctly.
