Might you give some more insights?
I also see problems with the sensor I’m reading. ERROR (MainThread) [homeassistant.components.luftdaten] Unable to retrieve data from luftdaten.info
Another solution could be by using the raw json data which Luftdaten is providing and using the following url: Lufdaten_raw_json
Then you could use the rest platform to extract the data.
I know it’s a hack, but hey it works
If you are unable to get it working please PM me so I could assist you in private with your own config/Luftdaten Id’s.
Maybe it’s a long shot, but can you help me with an example on how did you extracted the values from the data.json of the luftdaten firmware? I’m currently using it with command_line sensor like so:
I believe this is not the best solution, as is queries the devices multple times for multiple sensors (I want to get temperature, pressure, etc. from the device too).
