Lunar calender sensor help
I live in Vietnam and lunar calender is usually used for special event .
I want to make a sensor to convert date to lunar date.
Anyone can help me or show me the way to do so.
Thank in advance.
I found this can help [https://github.com/quangvinh86/SolarLunarCalendar] but i do not know programming.
Hi there, you could follow the implementation like this:
  1. Create the luna_calendar.py in the /python_scripts/ folder
import datetime
class LunarDate(object):
    _startDate = datetime.date(1900, 1, 31)
    def __init__(self, year, month, day, isLeapMonth=False):
        self.year = year
        self.month = month
        self.day = day
        self.isLeapMonth = bool(isLeapMonth)
    def __str__(self):
        return 'LunarDate(%d, %d, %d, %d)' % (self.year, self.month, self.day, self.isLeapMonth)
    __repr__ = __str__
    @staticmethod
    def leapMonthForYear(year):
        return None if no leap month, otherwise return the leap month of the year.
        return 1 for the first month, and return 12 for the last month.
        >>> LunarDate.leapMonthForYear(1976)
        8
        >>> LunarDate.leapMonthForYear(2023)
        2
        >>> LunarDate.leapMonthForYear(2022)
        start_year = 1900
        end_year = start_year + len(yearInfos)
        if year < start_year or year >= end_year:
            raise ValueError('year out of range [{}, {})'.format(start_year, end_year))
        yearIdx = year - start_year
        yearInfo = yearInfos[yearIdx]
        leapMonth = yearInfo % 16
        if leapMonth == 0:
            return None
        elif leapMonth <= 12:
            return leapMonth
        else:
            raise ValueError("yearInfo %r mod 16 should in [0, 12]" % yearInfo)
    @staticmethod
    def fromSolarDate(year, month, day):
        >>> LunarDate.fromSolarDate(1900, 1, 31)
        LunarDate(1900, 1, 1, 0)
        >>> LunarDate.fromSolarDate(2008, 10, 2)
        LunarDate(2008, 9, 4, 0)
        >>> LunarDate.fromSolarDate(1976, 10, 1)
        LunarDate(1976, 8, 8, 1)
        >>> LunarDate.fromSolarDate(2033, 10, 23)
        LunarDate(2033, 10, 1, 0)
        >>> LunarDate.fromSolarDate(1956, 12, 2)
        LunarDate(1956, 11, 1, 0)
        solarDate = datetime.date(year, month, day)
        offset = (solarDate - LunarDate._startDate).days
        return LunarDate._fromOffset(offset)
    def toSolarDate(self):
        >>> LunarDate(1900, 1, 1).toSolarDate()
        >>> LunarDate(2008, 9, 4).toSolarDate()
        datetime.date(2008, 10, 2)
        >>> LunarDate(1976, 8, 8, 1).toSolarDate()
        datetime.date(1976, 10, 1)
        >>> LunarDate(1976, 7, 8, 1).toSolarDate()
        ValueError: month out of range
        >>> LunarDate(1899, 1, 1).toSolarDate()
        ValueError: year out of range [1900, 2100)
        >>> LunarDate(2004, 1, 30).toSolarDate()
        ValueError: day out of range
        >>> LunarDate(2004, 13, 1).toSolarDate()
        >>> LunarDate(2100, 1, 1).toSolarDate()
        def _calcDays(yearInfo, month, day, isLeapMonth):
            isLeapMonth = int(isLeapMonth)
            res = 0
            ok = False
            for _month, _days, _isLeapMonth in self._enumMonth(yearInfo):
                if (_month, _isLeapMonth) == (month, isLeapMonth):
                    if 1 <= day <= _days:
                        res += day - 1
                        return res
                    else:
                        raise ValueError("day out of range")
                res += _days
            raise ValueError("month out of range")
        offset = 0
        start_year = 1900
        if self.year < start_year or self.year >= end_year:
        yearIdx = self.year - start_year
        for i in range(yearIdx):
            offset += yearDays[i]
        offset += _calcDays(yearInfos[yearIdx], self.month, self.day, self.isLeapMonth)
        return self._startDate + datetime.timedelta(days=offset)
    def __sub__(self, other):
        if isinstance(other, LunarDate):
            return self.toSolarDate() - other.toSolarDate()
        elif isinstance(other, datetime.date):
        elif isinstance(other, datetime.timedelta):
            res = self.toSolarDate() - other
            return LunarDate.fromSolarDate(res.year, res.month, res.day)
        raise TypeError
    def __rsub__(self, other):
            return other - self.toSolarDate()
    def __add__(self, other):
            res = self.toSolarDate() + other
        raise TypeError
    def __radd__(self, other):
        return self + other
    def __eq__(self, other):
        >>> LunarDate.today() == 5
        False
        if not isinstance(other, LunarDate):
            return False
        return self - other == datetime.timedelta(0)
    def __lt__(self, other):
        >>> LunarDate.today() < LunarDate.today()
        False
        >>> LunarDate.today() < 5
        TypeError: can't compare LunarDate to int
        try:
            return self - other < datetime.timedelta(0)
        except TypeError:
            raise TypeError("can't compare LunarDate to %s" % (type(other).__name__,))
    def __le__(self, other):
        # needed because the default implementation tries equality first,
        # and that does not throw a type error
        return self < other or self == other
    def __gt__(self, other):
        >>> LunarDate.today() > LunarDate.today()
        False
        >>> LunarDate.today() > 5
        return not self <= other
    def __ge__(self, other):
        >>> LunarDate.today() >= LunarDate.today()
        True
        >>> LunarDate.today() >= 5
        return not self < other
    @classmethod
    def today(cls):
        res = datetime.date.today()
        return cls.fromSolarDate(res.year, res.month, res.day)
    @staticmethod
    def _enumMonth(yearInfo):
        months = [(i, 0) for i in range(1, 13)]
        if leapMonth == 0:
            pass
            months.insert(leapMonth, (leapMonth, 1))
        else:
        for month, isLeapMonth in months:
            if isLeapMonth:
                days = (yearInfo >> 16) % 2 + 29
            else:
                days = (yearInfo >> (16 - month)) % 2 + 29
            yield month, days, isLeapMonth
    @classmethod
    def _fromOffset(cls, offset):
        def _calcMonthDay(yearInfo, offset):
            for month, days, isLeapMonth in cls._enumMonth(yearInfo):
                if offset < days:
                    break
                offset -= days
            return (month, offset + 1, isLeapMonth)
        offset = int(offset)
        for idx, yearDay in enumerate(yearDays):
            if offset < yearDay:
                break
            offset -= yearDay
        year = 1900 + idx
        yearInfo = yearInfos[idx]
        month, day, isLeapMonth = _calcMonthDay(yearInfo, offset)
        return LunarDate(year, month, day, isLeapMonth)
yearInfos = [
        0x04bd8,                                    #   /* 1900 */
        0x04ae0, 0x0a570, 0x054d5, 0x0d260, 0x0d950,#   /* 1905 */
        0x16554, 0x056a0, 0x09ad0, 0x055d2, 0x04ae0,#   /* 1910 */
        0x0a5b6, 0x0a4d0, 0x0d250, 0x1d255, 0x0b540,#   /* 1915 */
        0x0d6a0, 0x0ada2, 0x095b0, 0x14977, 0x04970,#   /* 1920 */
        0x0a4b0, 0x0b4b5, 0x06a50, 0x06d40, 0x1ab54,#   /* 1925 */
        0x02b60, 0x09570, 0x052f2, 0x04970, 0x06566,#   /* 1930 */
        0x0d4a0, 0x0ea50, 0x06e95, 0x05ad0, 0x02b60,#   /* 1935 */
        0x186e3, 0x092e0, 0x1c8d7, 0x0c950, 0x0d4a0,#   /* 1940 */
        0x1d8a6, 0x0b550, 0x056a0, 0x1a5b4, 0x025d0,#   /* 1945 */
        0x092d0, 0x0d2b2, 0x0a950, 0x0b557, 0x06ca0,#   /* 1950 */
        0x0b550, 0x15355, 0x04da0, 0x0a5d0, 0x14573,#   /* 1955 */
        0x052b0, 0x0a9a8, 0x0e950, 0x06aa0, 0x0aea6,#   /* 1960 */
        0x0ab50, 0x04b60, 0x0aae4, 0x0a570, 0x05260,#   /* 1965 */
        0x0f263, 0x0d950, 0x05b57, 0x056a0, 0x096d0,#   /* 1970 */
        0x04dd5, 0x04ad0, 0x0a4d0, 0x0d4d4, 0x0d250,#   /* 1975 */
        0x0d558, 0x0b540, 0x0b5a0, 0x195a6, 0x095b0,#   /* 1980 */
        0x049b0, 0x0a974, 0x0a4b0, 0x0b27a, 0x06a50,#   /* 1985 */
        0x06d40, 0x0af46, 0x0ab60, 0x09570, 0x04af5,#   /* 1990 */
        0x04970, 0x064b0, 0x074a3, 0x0ea50, 0x06b58,#   /* 1995 */
        0x05ac0, 0x0ab60, 0x096d5, 0x092e0, 0x0c960,#   /* 2000 */
        0x0d954, 0x0d4a0, 0x0da50, 0x07552, 0x056a0,#   /* 2005 */
        0x0abb7, 0x025d0, 0x092d0, 0x0cab5, 0x0a950,#   /* 2010 */
        0x0b4a0, 0x0baa4, 0x0ad50, 0x055d9, 0x04ba0,#   /* 2015 */
        0x0a5b0, 0x15176, 0x052b0, 0x0a930, 0x07954,#   /* 2020 */
        0x06aa0, 0x0ad50, 0x05b52, 0x04b60, 0x0a6e6,#   /* 2025 */
        0x0a4e0, 0x0d260, 0x0ea65, 0x0d530, 0x05aa0,#   /* 2030 */
        0x076a3, 0x096d0, 0x04afb, 0x04ad0, 0x0a4d0,#   /* 2035 */
        0x1d0b6, 0x0d250, 0x0d520, 0x0dd45, 0x0b5a0,#   /* 2040 */
        0x056d0, 0x055b2, 0x049b0, 0x0a577, 0x0a4b0,#   /* 2045 */
        0x0aa50, 0x1b255, 0x06d20, 0x0ada0, 0x14b63,#   /* 2050 */
        0x09370, 0x049f8, 0x04970, 0x064b0, 0x168a6,#   /* 2055 */
        0x0ea50, 0x06aa0, 0x1a6c4, 0x0aae0, 0x092e0,#   /* 2060 */
        0x0d2e3, 0x0c960, 0x0d557, 0x0d4a0, 0x0da50,#   /* 2065 */
        0x05d55, 0x056a0, 0x0a6d0, 0x055d4, 0x052d0,#   /* 2070 */
        0x0a9b8, 0x0a950, 0x0b4a0, 0x0b6a6, 0x0ad50,#   /* 2075 */
        0x055a0, 0x0aba4, 0x0a5b0, 0x052b0, 0x0b273,#   /* 2080 */
        0x06930, 0x07337, 0x06aa0, 0x0ad50, 0x14b55,#   /* 2085 */
        0x04b60, 0x0a570, 0x054e4, 0x0d160, 0x0e968,#   /* 2090 */
        0x0d520, 0x0daa0, 0x16aa6, 0x056d0, 0x04ae0,#   /* 2095 */
        0x0a9d4, 0x0a2d0, 0x0d150, 0x0f252,         #   /* 2099 */
def yearInfo2yearDay(yearInfo):
    '''calculate the days in a lunar year from the lunar year's info
    >>> yearInfo2yearDay(0) # no leap month, and every month has 29 days.
    348
    >>> yearInfo2yearDay(1) # 1 leap month, and every month has 29 days.
    377
    >>> yearInfo2yearDay((2**12-1)*16) # no leap month, and every month has 30 days.
    360
    >>> yearInfo2yearDay((2**13-1)*16+1) # 1 leap month, and every month has 30 days.
    390
    >>> # 1 leap month, and every normal month has 30 days, and leap month has 29 days.
    >>> yearInfo2yearDay((2**12-1)*16+1)
    389
    yearInfo = int(yearInfo)
    res = 29 * 12
    leap = False
    if yearInfo % 16 != 0:
        leap = True
        res += 29
    yearInfo //= 16
    for i in range(12 + leap):
        if yearInfo % 2 == 1:
            res += 1
        yearInfo //= 2
    return res
yearDays = [yearInfo2yearDay(x) for x in yearInfos]
def day2LunarDate(offset):
    res = LunarDate()
            break
        offset -= yearDay
    res.year = 1900 + idx
if __name__ == '__main__':
    import doctest
    failure_count, test_count = doctest.testmod()
    if failure_count > 0:
        import sys
        sys.exit(1)
from datetime import date
today = date.today()
lunar_today = LunarDate.fromSolarDate(today.year, today.month, today.day)
result = f"ngày {lunar_today.day} tháng {lunar_today.month} Âm lịch"
print(result)
  1. Continuing access to the configuration.yaml file and add this code:
# python scripts (incase you don't have it)
python_script:
  1. Finally, add lunar_calendar sensor to configuration.yaml file then restart the HA
command_line:
  # lunar_calendar today
  - sensor:
      command: "python3 /config/python_scripts/lunar_calendar.py"
      scan_interval: 1800 // <-- it's optional
      value_template: "{{ value }}"
