Lutron Aurora stops communicating after pairing
I’m attempting to setup a Lutron Aurora with my HA install. This is a new device, has not been paired with a Hue Bridge. I have a ConBee II and I’ve tried with both DeConz and ZHA. When I pair it, I can see it in the system, but once the interview is done, the Aurora no longer talks to the ConBee. If I click the middle button, I get 2 slow flashes from LED. HA shows the device, including the model, etc. If I delete the device and reset the Aurora, I have not trouble re-pairing with it. I bought this as part of a 2 pack, the 2nd unit is paired with my Hue Bridge and it works fine.
Problem solved, but want to add some context before giving the solution.
I’m in the process of migrating from using a Hue Bridge over to a ConBee II. When I bought the ConBee on Amazon, I bought a two pack of Lutron Aurora Dimmers to play with. After I installed the ConBee and migrated a couple of lights, I decided I pair a Aurora and try it out. After I had issues with the Aurora and made the OP, I moved on to migrating more lights. I was about 22 lights in when one of my new Hue bulbs started doing the same thing. It would pair, but ZHA (really any coordinator since I also had this issue with deConz) would lose visibility to it.
Something I learned a long time ago in the tech biz, when in doubt, shut it off. So I powered down my HA box, which means my Conbee was totally powered off.
After I powered it back on, wouldn’t you know it, when I paired the bulb again, it started working. Evern better, after pairing the Auroras, they started working. I can now see the events firing and my automations for controlling lights works flawlessly.
