I’ve done some searching here on the forum and I believe all of the Lutron Bridge threads I’ve come across deal with the Caseta line. My question concerns the Lutron RadioRA 2 Connect Bridge.
I’ve edited the configuration.yaml file with the correct IP address:
lutron:
lutron_host: 192.168.1.226
lutron_user: lutron
lutron_password: integration
But all I get from the web app is “Invalid Config” message. In the web app, Configuration | Server Management | Configuration Validation reports “valid.”
I’ve pasted the relevant entries from the log below. Any ideas for me?
17-04-18 10:11:14 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load C:\Users\Network Closet\AppData\Roaming\.homeassistant\known_devices.yaml: Config file not found: C:\Users\Network Closet\AppData\Roaming\.homeassistant\known_devices.yaml
17-04-18 10:11:16 ERROR (MainThread) [homeassistant.setup] Error during setup of component lutron
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 1026, in _send_output
self.send(msg)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 964, in send
self.connect()
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\http\client.py", line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\socket.py", line 722, in create_connection
raise err
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\socket.py", line 713, in create_connection
sock.connect(sa)
ConnectionRefusedError: [WinError 10061] No connection could be made because the target machine actively refused it
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\site-packages\homeassistant\setup.py", line 192, in _async_setup_component
None, component.setup, hass, processed_config)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\concurrent\futures\thread.py", line 55, in run
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\site-packages\homeassistant\components\lutron.py", line 36, in setup
hass.data[LUTRON_CONTROLLER].load_xml_db()
File "C:\Users\Network Closet\AppData\Roaming\.homeassistant\deps\pylutron\__init__.py", line 330, in load_xml_db
xmlfile = urllib.request.urlopen('http://' + self._host + '/DbXmlInfo.xml')
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 223, in urlopen
return opener.open(url, data, timeout)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 526, in open
response = self._open(req, data)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 544, in _open
'_open', req)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 504, in _call_chain
result = func(*args)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 1346, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\urllib\request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [WinError 10061] No connection could be made because the target machine actively refused it>
