I have tried adding this to my config, but haven’t had any luck getting it to work. I am using the smartbridge pro. Anyone get it to work or have any tips?
I had an issue with this myself, the pylutron-caseta package was failing to install. I ended up needing to install some additional packages on my Raspberry Pi and everything ended up working fine. That fix was described in this issue: https://github.com/home-assistant/home-assistant/issues/6806
Thanks, that seemed to work. I now see all of my caseta devices.
I also had “username” as “user” in the config. The example config shown on my link above shows “user”, while your link shows “username”. “username” appears to be the correct config.
Yes - it appears at this point, the pico remotes aren’t integrated. I have a couple as well, but I am using them in more of a 3-way setup to control associated caseta switches so it’s not that big of deal for me. It would be nice to integrate them though and use the buttons to trigger other things in HA as I do have a couple extra laying around.
Hey guys sorry I didn’t see this thread earlier. I will look into adding pico remotes. I think that would be very useful. I am having a bit of trouble adding just a pico remote without the setup asking for a device it should control. I really have not played with it too much.
