Hey everyone, I just finished a Home Assistant install (0.83.2) in virtualenv on a FreeNAS 11.2 jail yesterday, so far so good. Still very new to all of this.
I got stuck on trying to configure a Lutron Caseta Pro hub/bridge, following the upsert custom component method. After dumping the files into the custom_components directory alongside my configuration.yaml and attempting to restart HA via the GUI, here’s what the log reports:
Log Details (ERROR)
Mon Dec 03 2018 22:08:36 GMT-0600 (CST)
Error executing service <ServiceCall homeassistant.restart (c:df17676cd5964032a6e4095b5ba1180e)>
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
await service_handler.func(service_call)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/__init__.py", line 129, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/config.py", line 796, in async_check_ha_config_file
check_ha_config_file, hass)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 340, in check_ha_config_file
component = loader.get_component(hass, domain)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
module = importlib.import_module(path)
File "/srv/homeassistant/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/hass/homeassistant/custom_components/lutron_caseta_pro.py", line 24, in <module>
from . import casetify
File "/home/hass/homeassistant/custom_components/casetify.py", line 98, in <module>
class Casetify:
File "/home/hass/homeassistant/custom_components/casetify.py", line 101, in Casetify
loop = asyncio.get_event_loop()
File "/usr/local/lib/python3.6/asyncio/events.py", line 694, in get_event_loop
return get_event_loop_policy().get_event_loop()
File "/usr/local/lib/python3.6/asyncio/events.py", line 602, in get_event_loop
% threading.current_thread().name)
RuntimeError: There is no current event loop in thread 'SyncWorker_62'.
I doubled checked my config, IP and mac address check out:
## Lutron Caseta Pro
lutron_caseta_pro:
bridges:
- host: 10.0.1.30
mac: !secret mac_address
“Telnet Support” in the app is enabled. I have a duckdns hostname set up with SSL and port forwarding, all working as expected as far as I can tell. I looked at other faqs and posts, thankfully didn’t see any call for port forwarding or anything to the bridge.
Any ideas what I might be missing? Thanks in advance!
