I have been successfully using Home Assistant with a Lutron Caseta L-BDG-WH hub, but recently I had to un-plug both the caseta hub and the RPi that I am using to host Hass.io. Once restarting everything, Hass.io was able to reconnect with all other devices, and I am able to use my Lutron lights through the Lutron app and through Google home, but not through Hass.io. Looking through the logs I found this:
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
hass, processed_config)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/lutron_caseta.py", line 55, in async_setup
await bridge.connect()
File "/usr/local/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 40, in connect
yield from self._login()
File "/usr/local/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 281, in _login
self._reader, self._writer = yield from self._connect()
File "/usr/local/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 58, in _connect
family=socket.AF_INET)
File "/usr/local/lib/python3.6/site-packages/pylutron_caseta/leap.py", line 16, in open_connection
limit=limit, **kwds)
File "/usr/local/lib/python3.6/asyncio/streams.py", line 81, in open_connection
lambda: protocol, host, port, **kwds)
File "uvloop/loop.pyx", line 1879, in create_connection
File "uvloop/loop.pyx", line 1858, in uvloop.loop.Loop.create_connection
OSError: [Errno 113] Host is unreachable
That looks to me like the IP address for the Caseta hub was changed when I powered it up again, but I have it set as a static IP in my router, and I have checked and confirmed that it still has that IP address. At this point I am stumped, I’ve tried restarting Hass.io a few times with no luck. If anyone has run into this before or has any ideas, I am all ears.
