Hey all, this is my first post so feel free to let me know if there are ways to make it better.
I want my Lutron Caseta Diva switch to remember its brightness level just like a philips hue bulb while still letting the physical switch work just as before.
The way I did this is by making a template light which you control from your phone, and everytime you turn on the templated light it sets the correct brightness to the real light.
Here is the solution I came up with.
Name the physical Lutron switch something different than what you want to use. I named my switch: “nicks_bedroom_main_lights_lutron_switch”
Later we will create a template light with the proper name of the device you want to control. -
Install Home-Assistant-Variables: GitHub - snarky-snark/home-assistant-variables: A custom Home Assistant component for declaring and setting generic variable entities dynamically.
Add variable to configuration.yaml file:
var:
nicks_bedroom_main_lights_helper_brightness:
friendly_name: Nicks Bedroom Main Lights Helper Brightness
initial_value: 0
unique_id: "nicks_bedroom_main_lights_helper_brightness"
- Next make a template light. I have my templates set up to be individual files in a folder. Here is my “nicks_bedroom_lutron_helper.yaml” inside my template folder.
- light:
- name: "Nicks Bedroom Main Lights"
unique_id: "nicks_bedroom_main_lights_helper_template"
level: "{{ state_attr('light.nicks_bedroom_main_lights_lutron_switch', 'brightness') |int }}"
state: "{{ state_attr('light.nicks_bedroom_main_lights_lutron_switch', 'brightness') |int > 0 }}"
turn_on:
action: light.turn_on
entity_id: light.nicks_bedroom_main_lights_lutron_switch
brightness: "{{ states.var.nicks_bedroom_main_lights_helper_brightness.state }}"
turn_off:
action: light.turn_off
set_level:
- action: light.turn_on
brightness: "{{ brightness }}"
- action: var.set
entity_id:
- var.nicks_bedroom_main_lights_helper_brightness
value: "{{ brightness }}"
- Finally, we make an automation that updates the brightness variable whenever someone physically adjusts the brightness on the switch.
To add this, in HA go to settings/automations and create a new automation. In the upper right hand corner click “Edit in Yaml”. Paste this code:
alias: nicks_bedroom_main_lights_helper_automation
description: ""
triggers:
- trigger: state
entity_id:
- light.nicks_bedroom_main_lights_lutron_switch
attribute: brightness
conditions: []
actions:
- action: var.set
metadata: {}
entity_id: var.nicks_bedroom_main_lights_helper_brightness
value: "{{ state_attr('light.nicks_bedroom_main_lights', 'brightness') |int }} "
enabled: true
mode: single
Now in HA go to developer tools, make sure to check your configuration and then reboot HA (or just reload the yaml config.)
Hopefully all is working. I named my template light “Nicks Bedroom Main Lights” and use that exclusively as the entity to control my physical light.
Thanks!
