Lutron Caseta - Error upon start up: Unknown options lutron_caseta
Hi all,
I’m having a bit of a challenge with connecting a lutron smart hub to home assist.
I was able to configure the lutron certificate add-on, log into the lutron smart hub and add the certificate, then update the config.yaml to reflect the smart hub ip and cert.
Everything appeared fine, but I don’t see any of my switches under devices. I rebooted hassio adn noticed the below warning upon startup in the logs.
Any help would be greatly appreciated. This is my first venture into HA.
20-06-12 09:59:48 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-12 10:02:15 WARNING (MainThread) [supervisor.addons.validate] Unknown options lutron_caseta
20-06-12 10:02:15 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_a0d7b954_lutron-cert application
20-06-12 10:02:16 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on hassioaddons/lutron-cert-amd64 with version 0.5.2
20-06-12 10:02:16 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_lutron-cert
20-06-12 10:04:31 WARNING (MainThread) [supervisor.addons.validate] Unknown options lutron_caseta
20-06-12 10:04:33 INFO (SyncWorker_8) [supervisor.docker.interface] Stop addon_a0d7b954_lutron-cert application
20-06-12 10:04:37 INFO (SyncWorker_8) [supervisor.docker.interface] Clean addon_a0d7b954_lutron-cert application
20-06-12 10:04:37 WARNING (MainThread) [supervisor.addons.validate] Unknown options lutron_caseta
20-06-12 10:04:38 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on hassioaddons/lutron-cert-amd64 with version 0.5.2
20-06-12 10:04:38 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_lutron-cert
