Lutron Caseta Failed to Set Up
I wasn’t sure where to put this, but I am having a problem getting the Lutron Caseta Integration to setup. I think that this is because I have no buttons with my system.
I am pretty sure that the fix is to change pylutron_caseta/smartbridge.py line 929 from:
for button_json in button_expanded_json["Buttons"]:
To:
for button_json in button_expanded_json.get("Buttons", []):
I tried to do this, but clearly I don’t understand enough about how docker or patching or pretty much anything works. :frowning:
Here are my logs:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 388, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/__init__.py", line 176, in async_setup_entry
    await bridge.connect()
  File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 105, in connect
    await self._login_completed
  File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 695, in _login
    await self._load_ra3_devices()
  File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 800, in _load_ra3_devices
    await self._load_ra3_control_stations(area)
  File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 856, in _load_ra3_control_stations
    await self._load_ra3_station_device(
  File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 929, in _load_ra3_station_device
KeyError: 'Buttons'
