Lutron Caséta Integration: Pico Remote Double Click + Hold Events
The Lutron Pico remote is a small, very low-latency battery-powered remote with up to five buttons, which works great with Home Assistant. If Home Assistant could handle double-clicks and holds on these buttons, it would allow this tiny versatile remote to trigger 15 different automation behaviors.
Currently, the Lutron Caséta integration does not handle buttons on the Lutron Pico remote being double-clicked or held down. This is hard functionality to implement in an automation. Ideally, the integration would trigger button events (as it already does), or special events for these particular types of button presses.
The idea has been bounced around in years past, and a custom integration handled this functionality at one point in time. It appears native support for these button events may depend on having a Pro hub, but the integration could easily detect these button presses on the HA side in the absence of hub support.
I’d like the functionality, but without lutron native support, I don’t think we will ever see it.
AFAIK, the fork of the old third party caseta-pro integration that added support should still work.
I create a template entity to supply multi-press and long-press events for picos where I need them.
How are you doing that? Using timers I assume?
No timers.
A template entity can have attributes, so I store time of last press and press count in attributes, then the template reads its own attributes on subsequent press/release events to determine multi-press count vs long press, etc.
Would you be able to share your template?
