Hello all,
So I currently use the custom Lutron integration and was hoping to move everything to the core Lutron Caseta Integration.
After installing it and configuring the integration I notice this error in the logs:
Failed to connect to via LIP at 192.168.30.10:23, Pico and Shade remotes will not be available; Enable Telnet Support in the Lutron app under Settings >> Advanced >> Integration
Telnet is configured in the Lutron Smart Bridge PRO. I’m able to use Putty on a separate computer and I can see messages being sent when I press buttons on a Pico and/or other switches. The IP for the smart bridge is static (192.168.30.10).
My Home Assistant setup is as follows. It runs as Hass OS 2021.6.3 (Hass.IO VM) inside an unRAID Server. I’m wondering if this is a network setting and/or something is blocking the Telnet from the HA machine to the PRO Smart Bridge. I’ve tested it from 2 computers and I know the Telnet service is working.
Any thoughts/suggestions are much appreciated.
Thank you
