Is anyone else having problems with their Caseta Hub today? Maybe their servers are offline… but is has been several hours now.
This component has been working without issue for a month. Suddenly this morning when I rebooted my Raspberry Pi it gave me the following error:
The following components and platforms could not be set up:
lutron-caseta
Please check your config.
The config entry hasn’t changed. The IP Address is still reserved on my router. The key file and certificate files are all still in the /config directory. And I restarted both my router (it is hard wired) and the Caseta Hub, and restarted Home Assistant. No luck.
2018-04-17 08:01:54 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-04-17 08:02:01 ERROR (MainThread) [homeassistant.setup] Error during setup of component lutron_caseta
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 142, in _async_setup_component
result = await component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/lutron_caseta.py", line 57, in async_setup
yield from bridge.connect()
File "/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 40, in connect
yield from self._login()
File "/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 284, in _login
yield from self._load_devices()
File "/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py", line 314, in _load_devices
for device in device_json['Body']['Devices']:
KeyError: 'Body'
Sorry, the duplicate posting was unintentional. Since the problem only cropped up for me this morning I did a quick scan of the top 10 or so posts before I wrote this. Maybe I had been spared thus far because I have mostly been reloading instead of rebooting.
The timing was just disappointing because I rewrote my light automation routines yesterday and somehow my bedroom light woke me up early when my son went downstairs, and my wife has been getting impatient with the inconsistent light situation here.
Just to follow up. I have solved this problem by ripping the Caseta Hub out of the loop. I paired the Caseta devices with my Wink hub and am back online. It has taken a couple of days to get the bugs worked out, but I think the house is finally almost back to where it was. (For some reason my instead dimmer modules started acting up after this switchover, but it is probably something I did.)
