Hi All,
New to HA - liking it so far but Lutron Caseta is a fail for me.
- Running 0.62.1
- I have run the get_lutron_cert successfully and gotten all the keys
- Placed keys in config dir, updated configuration.yaml with:
Lutron
lutron_caseta:
host: 196.168.1.40
keyfile: caseta.key
certfile: caseta.crt
ca_certs: caseta-bridge.crt
- Looked at the key files, they look reasonable
- Verified I have the right IP for my Lutron (non-pro) bridge
- Verified I can ping the bridge from my Pi3
I always get this error:
2018-02-10 16:13:03 ERROR (MainThread) [homeassistant.setup] Error during setup of component lutron_caseta
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 196, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File “/usr/lib/python3.6/site-packages/homeassistant/components/lutron_caseta.py”, line 57, in async_setup
yield from bridge.connect()
File “/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py”, line 40, in connect
yield from self._login()
File “/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py”, line 281, in _login
self._reader, self._writer = yield from self._connect()
File “/usr/lib/python3.6/site-packages/pylutron_caseta/smartbridge.py”, line 58, in _connect
family=socket.AF_INET)
File “/usr/lib/python3.6/site-packages/pylutron_caseta/leap.py”, line 16, in open_connection
limit=limit, **kwds)
File “/usr/lib/python3.6/asyncio/streams.py”, line 75, in open_connection
lambda: protocol, host, port, **kwds)
File “uvloop/loop.pyx”, line 1733, in create_connection
File “uvloop/loop.pyx”, line 1712, in uvloop.loop.Loop.create_connection
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
TimeoutError: [Errno 110] Operation timed out
Help very much appreciated!
xnappo
