I am unable to connect my Lutron Dimmer to my hub. I use to have a Staples Connect and I guess it had this radio wave Clear Connect in it because it worked through there.
I called Lutron looks like I am going to need a bridge or a Wink hub thinking Wink is going to be the cheaper route as this is my only dimmer with this. Challenge is my house is only 2 wire
Do you have Lutron Caseta switches and hub? There as a Home Assistant component that works pretty well with it. It just requires you to run a python script to generate a token that you store on the Home Assistant instance.
I don’t really follow your question. What hub are you trying to connect to? Home Assistant or Lutron Caseta? Could you be more specific?
