New to HA 2024.7.1, migrating from Homeseer.
Integration: Lutron RadioRa2.
I’ve been testing the Lutron integration for the past couple of weeks an I can’t figure out how to get HA to stop this 50% dimming business. Whenever HA restarts, the next turn-on for any Lutron dimmer via any dashboard is 50%. It’s driving me crazy. As soon as I dim it up to 100%, then HA will toggle between 0% and 100%…until the next restart. If I use a Lutron scene to turn the light on, then it’s always at 100% (because all my Lutron scenes are programmed that way) and from that time onward HA will use 100% during a toggle.
Big thing #1: I know that Lutron switches are set to a default dim level; I am a Lutron integrator (in the loosest sense) and programmed in the default dim levels of all my dimmers when I first installed them 8yrs ago, and those levels persist power outages and stuff because 100% of Lutron programming is set to dim to 100% on toggle. This is literally an issue only with HA in the last 2 weeks of testing.
Big thing #2: I’ve looked around a ton and there are options I see for “setting default dim in programming”. I have like 5 dozen switches and definitely do not want to set a default level for each one; somewhere there is a global default in HA and that is what I’m trying to find. That is where the problem lies.
Any insights?
