I have recently integrated my Lutron system that includes light/dimmer modules and motor modules into the HA (Lutron - Home Assistant). All the lights, dimmers, scenes and sensors are viewable and controllable through HA.
However, the Lutron motor modules are recognized by HA as light entities and not as cover entities. As the motors require open, stop, close signals and the light
entity has only ON/OFF signal, I’m unable to control any of the covers/shades.
I might be able to help you. Are you using the Lutron integration? (not the caseta one)
Do you know how to get a copy of your xml DB? Have you tried the latest release? There have been a LOT of updates with 2024.2.x
Yes, I’m using the Lutron integration (updated to the last version). After the updates the motor module still recognized by HA as a light.
I don’t know how to get a copy of the xml DB.
OK I got the file. I’m a little surprised that anything is working for you looking at the structure of this. I’m going to guess that your firmware is quite outdated. The XML is REALLY poorly structured and has a ton of errors in it. I can only assume that a later firmware version would clean this up. For instance at the moment, the entire home is contained in the area called “Attic” I’m pretty sure that isn’t the case but the XML errors cause that to be true.
I found your shade modules and the reason they are showing up as lights is because they are labeled as MOTOR and the API layer (pylutron) is looking for SYSTEM_SHADE. This could be as simple as adding another parameter to look for MOTOR but without knowing a few more details that could be problematic.
Just to confirm, is “M1/4 פרגולה” aka “M1/4 Pergola” one of your shades?
Do you have model numbers for the shades and controllers so that we know which device parameters to actually use?
When added as lights, do they work if you raise or lower the dim level of the light? (That will tell me if the commands are correct or not)
Indeed the firmware is outdated (10 years ago). However, I don’t wish to update it as the current update blocks the Lutron Home app.
Yes, M1/4 is one of the shades. The model number of the motor controller is LQSE-4M-D.
They dont work when raising the dim level (the bar remains grey).
ok. side note: maybe how you saved the XML file (the browser) attempted to correct the XML and made it messy. I’ve not worked with a homeworks system before but maybe try a different browser and we might get a cleaner file (not super critical, but would be helpful)
I’m not sure how tech familiar you are but what would be ideal is for you to be able to test the commands since I don’t have your system to test against. You’ll need a telnet connection to your Homeworks Processor. You can use the windows telnet command or download PuTTY. If you use PuTTY be sure to choose telnet as it defaults to SSH and that should then switch the port to 23.
We need to verify the commands so I know we are working from the right device instructions. When you make the telnet connection, login with the same username and password as in your HA integration. Have your phone app handy in case you need to override one of the commands we issue. The below is using your M1/1 Silhouette motor.Start with the shade closed. The commands below then will raise the shade, stop raising the shade, lower the shade, and stop lowering the shade.
Here are the commands to enter (type the text as shown and press enter after each line and you should see it take action):
Assuming that works then this will be a pretty easy update to pylutron. The HA integration should then detect them as covers and it will work for full open and full close the way it is coded now. But the other shades support setting a specific position and it looks like the Homeworks motor does not. So we will want to work on that a bit.
If it works, the next thing I’ll have you try is modifying pylutron directly in your HA node. It’s a pretty simple update but you’ll need to get access via SSH to your HA in order to do it. How are you running HA? have you done that before?
Here is a general guide to the process: Debugging the Home Assistant Operating System | Home Assistant Developer Docs
Ultimately we need in the container bash. So you can modify the above or however you need to get there. Reach back if you can’t figure this part out.
Let me know how your testing goes and we’ll take next steps.
I’m working with an old homeworks illumination system and all devices (lights, switches, fans and shades) come in as lights. I was able to create template devices for switches and fans and they work well. The template shade device I wrote will open and close the shade, and will even set percentage when the slider is set. But it will not show current position or open/closed status. I guess I’ll have to do some more digging.
Hi. I have the same issue, because the installer told me the shades werent native Lutron, so I could neves control them through homekit (and couldnt add them to automations on the lutron app), so I figured I could add them to homekit through HA, and I did, but they show up as lights and cannot control them. Can you please tell me how you managed to control them? If possible in a “for dummies” way. Thanks a lot
In my case, I’m using the lutron homeworks integration and realized that the issue was in the pyhomeworks code. The homeworks system reports shade levels as a float. So I copied over the pyhomeworks project to my HA, modified it to turn that value into an int. Then pulled in the homeworks integration as a custom component and point it to my local pyhomeworks. Works great now.
Hi Wilbur.
I have the exact same issue discussed in this post, I checked my XML and also see shades appearing as “MOTOR” instead of “SYSTEM_SHADE”.
I also performed the suggested test as you wrote in your reply with PuTTY, and was able to toggle the shades using a similar command.
I would love your help on how I can get this to work with Home Assistant. I am running HA on my Synology NAS via docker, so I don’t know if I can modify the pylutron code directly.
Appreciate your help, it already helped diagnose much of the problem.
