Lutron HomeWorks QS Keypad Integration
Hi I have a HomeWorks QS system and the idea is to use Lutron keypads in order to run HA scripts. I have installed the Lutron integration and can see the processor etc however am unable to see the lutron_event (which I believe should register the keypad presses) in Developer Tools. Is anyone able to help/provide some guidance please?
each button on my lutron homeworks qs shows up as an event entity:
and the presses on the buttons look like this:
Thanks @armedad appreciate the screenshots.
Looks like there may be an issue the way my keypads are setup in the Lutron designer software - how are they setup there do you know?
sorry, i’m not able to answer that. i can only see it from the lutron mobile app side, control4 side (they do expose as separate entities in control4 as well) and ha side.
since i have a control4 system, i wonder if the installer had to do an extra config to expose them to control4 which then had the side effect of exposing them to ha.
Thank you anyway that was helpful - I take it you use the Lutron core integration (not homeworks or Caseta)?
yeah, i use this:
Does anyone else have any tips to expose the keypads in HA? I can telnet into the keypads fine they are just not appearing in the lutron integration.
To close this out the integration didn’t have support for Palladiom keypads, however pylutron has now been updated alongside the integration and the keypads appear as they should in HA
Hello - sorry to dig this one out. Wondering which integration are you using? Is it the official Lutron integration (Lutron - Home Assistant)?
There is another dedicated QS integration that used to work well as a custom component (GitHub - rzulian/lutron_custom_component: Lutron custom component for HA using pylutron). I could still get it to work and it supports advanced controls such as SYSVAR but a lot of manual overrides so wanted to ask the folks here if there is an easier route now.
Thank you in advance!
