Folks,
Got a weird problem with my Lutron RA2 Select bridge. My Lutron setup largely works in HA - I have a mix of pico remotes and RRD-PRO dimmers. However, I just added a couple of hard-wired dimmer and switch modules (LMJ-5T-DV-B and LMJ-16R-DV-B).
None of the LMJ-* devices are picked up by the Lutron integration but they are active in the Lutron setup. The Lutron integration is still sync’d with the bridge (as I’m seeing state changes and name changes) so I’m assuming that neither of these modules are spotted by the code as being valid.
Had a browse thru the Python for the component but can’t really spot any obvious places where this could be added.
Pointers? Clues?
Thanks!
Scott…
