Lutron is broken on 0.47.1
Hi all,
Lutron is broken on 0.47.1. The only change was https://github.com/home-assistant/home-assistant/pull/7963 from @fabaff
Can someone help ?
Thanks!
The configuration was updated and this was mentioned in the release notes.“is broken” means most likely that your configuration is outdated which results in a validation error.
Possible duplicate of https://community.home-assistant.io/t/lutron-devices-suddenly-not-working-with-ha-0-47-1/
Thanks @fabaff!
I indeed updated the configuration.
And yes it is a duplicate of the issue you mentioned. I get the config, but the lights states are not ok and i can not turn them on/off.
Are you guys aware of this breakage?
Tks!
