Anyone been successful in getting the Lutron PD-5S-DV-WH switch to work with HA? This is the 5 amp switch that does not require a neutral wire.
I have the Pro version of the Lutron bridge and am using the lutron_caseta_pro
custom component to integrate the devices into HA since I want Pico functionality. I have a bunch of dimmer switches, fan controls, and Pico remotes installed throughout the house, and they are all working correctly.
I now have the PD-5S-DV-WH switch installed and registered with the Lutron app and it works fine. It shows up as device 30 in the integration report. I also have a Pico remote configured to control the switch via the Lutron app and that works fine, too.
What I observe is that if I do not configure the PD-5S-DV-WH as a switch (leave it to be detected by default as a light), it appears in HA as light.master_bathroom_exhaust_fan
and can be switched on/off. It has a dimmer slider control, and that’s not applicable to a switch. However, if I add it as a switch via the configuration.yaml file
, it is not recognized at all and there is no corresponding entity in HA.
This is my configuration.yaml
content when adding it as a light, and this results in light.master_bathroom_exhaust_fan
being present in the HA entities list :
lutron_caseta_pro: # Lutron Caseta PRO Bridge
bridges:
- host: !secret ip_address_lutron_caseta_pro_bridge
mac: !secret mac_address_lutron_caseta_pro_bridge
default_transition_seconds: 1.0
fan: [ 23, 24 ]
content when adding it as a switch, and there is NO HA entity for the switch. I was expecting something like switch.master_bathroom_exhaust_fan
bridges:
switch: [ 30 ]
fan: [ 23, 24 ]
The relevant lutron_caseta_pro_<ip_address>.json
file contents are:
"LIPIdList" : {
"Zones" : [
"ID" : 30,
"Name" : "Exhaust Fan",
"Area" : {
"Name" : "Master Bathroom"
Any ideas what might be wrong here or tips on how to debug this? I’m in month 2 of using HA, so I’m still figuring stuff out and would appreciate any suggestions on how to get the device detected as a switch.
