Lutron Pico 4 Button 2 Group Blueprint - PJ2-4B-XXX-L21
Here’s a blueprint based on the several floating around. This one is for the 4 button Pico that is mean to control two lights (on/off).
My coding twist was to use trigger ids. Hopefully useful to someone else! Cheers.
blueprint:
  name: Lutron Two Group Four-Button Pico Actions
  author: robchandhok
  homeassistant:
    min_version: 2025.1.0
  description: |
    ## Pico 2 Group remote (4 button) Blueprint (v0.2)
    A blueprint to make it easy to map button presses from the Lutron Caseta integration for a PJ2-4B-XXX-L21, which is on/off for 2 devices.
    ### Software Version Requirements
    Not tested on versions of Home Assistant before March 2025
    ## Thanks
    Shout out to mattsheffiel and stephack for their previous variants that this is based on.
  domain: automation
  source_url: https://raw.githubusercontent.com/robchandhok/homeassistant-blueprints/refs/heads/main/automation/lutron-caseta-pico-2-group-remote.yaml
  input:
    pico:
      name: Pico Two-Group Four-Button Remote
      description: Select the pico four-button scene remote to configure.
      selector:
        device:
          integration: lutron_caseta
          model: PJ2-4B-XXX-L21 (Pico4Button)
          multiple: false
    button_1_press:
      name: Group 1 On Pressed
      default: []
      selector:
        action: {}
    button_1_released:
      name: Group 1 On Released
      default: []
      selector:
        action: {}
    button_2_press:
      name: Group 1 Off Pressed
      default: []
      selector:
        action: {}
    button_2_released:
      name: Group 1 Off Released
      default: []
      selector:
        action: {}
    button_3_press:
      name: Group 2 On Pressed
      default: []
      selector:
        action: {}
    button_3_released:
      name: Group 2 On Released
      default: []
      selector:
        action: {}
    button_4_press:
      name: Group 2 Off Pressed
      default: []
      selector:
        action: {}
    button_4_released:
      name: Group 2 Off Released
      default: []
      selector:
        action: {}
- platform: device
  device_id: !input pico
  domain: lutron_caseta
  type: press
  subtype: button_1
- platform: device
  type: release
  subtype: button_1
- platform: device
  type: press
  subtype: button_2
- platform: device
  type: release
  subtype: button_2
- platform: device
  type: press
  subtype: button_3
- platform: device
  type: release
  subtype: button_3
- platform: device
  type: press
  subtype: button_4
- platform: device
  type: release
  subtype: button_4
actions:
  - choose:
    - conditions:
      - condition: trigger
      sequence: !input button_1_press
    - conditions:
      sequence: !input button_1_released
    - conditions:
      sequence: !input button_2_press
    - conditions:
      sequence: !input button_2_released
    - conditions:
      sequence: !input button_3_press
    - conditions:
      sequence: !input button_3_released
    - conditions:
      sequence: !input button_4_press
    - conditions:
      sequence: !input button_4_released
mode: restart
Hello Im trying to get this blueprint to work with a PK2-4B-TXX-X21 (Pico4Button2Group) I have updated the model in the YAMl file and Im able to select my pico remote, however the automation is not recognizing the button presses. Im very new to this so if you could help me in anyway I would greatly appreciate it
Sorry - didn’t see this. Did you get it working? You can look in “activity” in home assistant when you push the buttons to see what event is being fired. It’s possible your model sends different events - I didn’t test against the euro version.
This integration might be an alternative… https://github.com/smartqasa/pico-link
