Lutron Radio RA2 lights status are not being reflected in the cards
So I have Radio RA2 lights. As a test, I created two cards. One is a Glance card the other a regular one for the lights. A few issues I noticed:
If I adjust the brightness using that glance card, it does not reflect by the other card
If I adjust the light manually, it does not reflect by either card
The glance card says the light is off, even if I move the slider and the light turns on.
Any suggestions?
Thank you
I am having the same issue, but I am using Lutron Caseta switches. Anyone have a solution?
Anyone? I am trying to test out HA, but I am dead in the water
Anyone?
Thank you
Have you had any success with state status on your Radio RA2 lights? I’m having this same problem.
Nope. Sorry
