Lutron RadioRa2 5button pico - Media Player controller
Hello! I base this on my other blueprint to make this to work as a media controller.
This is intended to work with the 5 button pico device from lutron (on, off, raise, lower, favorite).
In this blueprint the central buttons, favorite, raise and lower will work as play/pause, raise and lower volume.
You can customize the main on/off button (I use it to call a service on spotcast to play my favorite playlist and the other button my wife’s favorite)
Enjoy and improve!
blueprint:
  name: RadioRa2 Pico 5 button as MediaPlayer controller
  description: "This is for the 5 button picos that have the following model:\n\n PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)\n\nSelect an action for each button listed below. \n\n Based on the work of stephack \n\n The favorite button will play/pause the media, arrows buttons will raise and lower the volume"
  domain: automation
  input:
    pico_remote:
      description: "Go to Developers Tools--> Events --> Listen event: lutron_event --> start listen. Push a button of your pico and write here the name on data:id: (without quotes) and without the last underscore and word (ex. without  _favorite)"
    media_player:
      description: "Select the media player to use with the pico remote:"
      selector:
        entity:
          domain: media_player
    top_on:
      name: Top (On) Button Pressed
      description: "Execute when TOP button is PRESSED"
      default: []
      selector:
        action: {}
    bottom_off:
      name: Bottom (Off) Button Pressed
      description: "Execute when BOTTOM button is PRESSED"
      default: []
      selector:
        action: {}
variables:
  pico_name: !input pico_remote
  - platform: event
    event_type: lutron_event
condition:
  - condition: template
    value_template: '{{ pico_name in trigger.event.data.id  }}'
  - choose:
    - conditions:
        value_template: >-
              {{ trigger.event.data.action == "single"  or
              trigger.event.data.action == "pressed" }}
      sequence:
        - choose:
          - conditions:
              value_template: '{{ "_off" in trigger.event.data.id }}'
            sequence: !input bottom_off
          - conditions:
              value_template: '{{ "_favorite" in trigger.event.data.id }}'
            sequence:
              - service: media_player.media_play_pause
                  entity_id:
                    - !input media_player
          - conditions:
              value_template: '{{ "_on" in trigger.event.data.id }}'
            sequence: !input top_on
          - conditions:
              value_template: '{{ "_raise" in trigger.event.data.id }}'
            sequence:
              - repeat:
                  until:
                      value_template: '{{  trigger.event.data.action == "released"  }}'
                  sequence:
                    - service: media_player.volume_up
                        entity_id:
                    - delay:
                        hours: 0
                        minutes: 0
                        seconds: 0
                        milliseconds: 200
          - conditions:
              value_template: '{{ "_lower" in trigger.event.data.id }}'
            sequence:
              - repeat:
                  until:
                  sequence:
                    - service: media_player.volume_down
                        entity_id:
                    - delay:
                        hours: 0
                        minutes: 0
                        seconds: 0
                        milliseconds: 200
          default: []
    default: []
mode: restart
