Lutron RadioRA2 devices not updating
I’m new to HASS. Just installed it on Raspberry PI a few days ago, but I can’t get the my lutron RadioRA2 to work properly. I added it to my configuration.yaml file, and everything loads up just fine. However, all of the devices display as “off”. I can turn them on through the interface, but they immediate turn back off (just the interface, the lights actually stay on). Basically, the status of the devices are not being updated. When I got back to the log it shows the devices as off, and then “unknown” for a few minutes until they are turned back off. Any idea what’s going on?
Oh, I should also mention that all of my devices are dimmers.
Did you solve this problem? I’m having the exact same issue running HA 0.93.1 to a RadioRa2 Master Repeater; however, I do know my Main Repeater firmware is old, I’m not sure if that has anything to do with it.
@cgtobi and @balloob are contributors to the lutron component and it seems like this one is a little tricky. Perhaps this is a current limitation of the HA component or of pylutron?
