Lutron stopped working. Any ideas why? (SSL-related?)
Hi, my Lutron component just started to fail since two days ago. Looks like it has something to do with SSL, but as a HA novice, I was not able to pinpoint where the issue is, nor did Googling did me much help. Any help would be much appreciated! Logs as follows:
Fri Jul 13 2018 16:49:59 GMT-0400 (Eastern Daylight Time)
Error during setup of component lutron_caseta
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 143, in _async_setup_component
hass, processed_config)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/lutron_caseta.py”, line 57, in async_setup
yield from bridge.connect()
File “/srv/homeassistant/lib/python3.5/site-packages/pylutron_caseta/smartbridge.py”, line 40, in connect
yield from self._login()
File “/srv/homeassistant/lib/python3.5/site-packages/pylutron_caseta/smartbridge.py”, line 281, in _login
self._reader, self._writer = yield from self._connect()
File “/srv/homeassistant/lib/python3.5/site-packages/pylutron_caseta/smartbridge.py”, line 58, in _connect
family=socket.AF_INET)
File “/srv/homeassistant/lib/python3.5/site-packages/pylutron_caseta/leap.py”, line 16, in open_connection
limit=limit, **kwds)
File “/usr/lib/python3.5/asyncio/streams.py”, line 75, in open_connection
lambda: protocol, host, port, **kwds)
File “/usr/lib/python3.5/asyncio/base_events.py”, line 801, in create_connection
sock, protocol_factory, ssl, server_hostname)
File “/usr/lib/python3.5/asyncio/base_events.py”, line 827, in _create_connection_transport
yield from waiter
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/asyncio/sslproto.py”, line 502, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File “/usr/lib/python3.5/asyncio/sslproto.py”, line 201, in feed_ssldata
self._sslobj.do_handshake()
File “/usr/lib/python3.5/ssl.py”, line 641, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:720)
Looks like I can’t delete my own thread. But here’s the fix: https://github.com/home-assistant/home-assistant/issues/15421
Tried to follow instructions, but not sure how do to it on HASS.IO image. Anyone have a clue?
I believe it’s the same method. Remote into your source files and change that file.
