Is it possible to connect a light sensor to a sonoff basic?
To measure lux and switch lights if it gets dark?
Cant find a good solution!
Iām using the BH1750 (Link anchor doesnāt work, scroll down a bit) sensor.
Hereās my config on Sonoff Basic
You need only SCL and SDA.
So you only connect two wires at the sonoff?
Does it send the lux with the sonoff mqqt?
Do you have picture of your setup?
The sensor needs 3.3V, ground and the 2 wires for the i2c bus. = 4 wires
Yes
No, not at the moment. But i used the RX/TX pins for SCL/SDA
Nice i will order one to test!
So tx is scl and Rx is Sda?
Does it send lux levels continue? Or in few minutes?
Not sure, i have to open the device in the evening.
But itās no problem to change them, nothing getās broken if they are wrong.
That depends on the TelePeriod Parameter on the Sonoff.
Minimal is 10 seconds, i think.
Good enough to turn on light when gets dark.
I ordered it today so tomorrow i can test it.
Hope works good!
I connected it and the lux level show in the sonoff menu.
How do i get the lux value in home assistant?
I thought it appears automaticly
You need a sensor.
- platform: mqtt
state_topic: "tele/sonoff01/SENSOR"
value_template: "{{ value_json['BH1750'].Illuminance }}"
unit_of_measurement: "lx"
The state_topic ātele/xxxxxx/SENSORā depends on what you have configured in mqtt on the sonoff.
It worked!
Changed the TelePeriod to lower value and now it shows the actual lux!
thanx for your help!
Hi there,
This one doesnāt work for me for whatever reason.
I have this config:
- platform: mqtt name: D1mini illuminance state_topic: ātele/D1mini_illuminance/SENSORā value_template: ā{{ value_json[ 'BH1750' ].Illuminance }}ā unit_of_measurement: "lx"
I run hass v0.88.0
Noob question!
Will this work, if i connect the sensor to my sonoff as described, without changing to tasmota firmware?
As it is now, all my sonoff devices run via ewelink with standard firmware, i have different versions (with power sensors, temperature sensors, etc.), and my Hassio setup automatically detect the devices and their sensors, as soon as they have been added to Ewelink.
I know this might be a somewhat stupid presumption, but i know next to nothing about fiddling with this stuffā¦ My thought is that the current firmware might recognize the sensor or maybe the sensor sends understandable data to the sonoff deviceā¦
I donāt think so.
Or is it possible to configure pins, i2c, ā¦ in Ewelink?
No, there are no options for configuration at all in Ewelink.
Will update to Tasmota instead!
remember to get the ātasmota-sensors.binā file, as this will not work with regular versions, or at least not the ones i tried at firstā¦
