Hi Not sure why my philip lux sensor does not work in Node-Red I did try something very simple, just add a “current state” and a “debug” Write the sensor in “Entity ID” in current state and save/deploy. But no value show in debug window.
Did even restart Node-Red but no change
Restart HA too. Then look through the logs. If that fails then post a screenshot of the developer tools and of the NR node you are testing with.
Current state needs an input
Use an event state if you want a trigger for an automation.
Ahh thanks
