LVGL and buttonmatrix
I have a bit of a problem here. I want to have a buttonmatrix with lights in it.
And then I want to change
checked
disabled
recolor
But when I try to do this with a lambda, it does not work.
This is what I do:
  - platform: homeassistant
    entity_id: light.taklampe_2_gang
    on_value:
      then:
        - lvgl.matrix.button.update:
            control:
              checked: !lambda return (0 == x.compare(std::string{"on"}));
              disabled: !lambda return ((0 == x.compare(std::string{"unavailable"})) or (0 == x.compare(std::string{"unknown"})));
and
              - buttonmatrix:
                  align: CENTER
                  pad_all: 0
                  outline_width: 0
                  border_color: black
                  border_width: 0
                  border_opa: TRANSP
                  x: 0
                  y: 40
                  width: 300
                  height: 50
                  bg_color: black
                  text_color: 0xD3D3D3
                  text_font: mdi_42
                  items:
                    shadow_opa: TRANSP
                    bg_color: black
                    border_color: black
                    border_width: 0
                    border_opa: TRANSP
                  rows:
                    - buttons:
                      - id: ceiling_light_symbol
                        text: "\U000F17C7"
Leads to:
Failed config
text_sensor.homeassistant: [source /config/esphome/esp-screen-kitchen.yaml:620]
  on_value:
    then:
          control:
            This option is not templatable!.
            checked: !lambda |-
            disabled: !lambda |-
Is there another way to do this?
I like using a flex grid of individual buttons instated of a button matrix for this type of application. It’s much more flexible and works better.
I just finished building a library that you can use. You can add a button with just one line of code!
Here is a picture of what it looks like on an LCD screen.
This example should get you up and running quickly.
The control options are not templatable, but you can just use something like:
        on_press:
          - lvgl.widget.update:
              state:
                checked: true
Where button_c is a matrix button, This will be translated into the correct code for a matrix button, and the checked value is templatable.
Thank you! Literally just got up to a part in my project that required this workaround… works perfectly!
I did something like that to set the color of my buttons. And used a theme for making the text (mdi:icon) yellow when the light is on, and white when it’s off:
    entity_id: light.taklampe_1_stue
    on_value:
      - if:
          condition:
            text_sensor.state:
              state: "on"
          then:
            - delay: 500ms
                control:
                  checked: true
          else:
            - delay: 500ms
                control:
                  checked: false
The delay is for the lights to catch up before changing state on checked. If I didn’t have it, sometime the light and the button got out of sync.
