I have created a battery symbol, where the outline is made up of simple lines, the variable SOC ‘contents’ is a bar and then there is an additional label on the right hand side with the SOC value in %.
Then I have defined a minimum SOC value where the color of the whole thing shall change from green to red.
Everything works as expected with the exception of the bar indicator color. This seems to stay at the original value and does not change.
# symbol for battery low warning
- obj:
x: 420
y: 2
width: 60
height: 24
bg_color: 0
pad_all: 0
outline_width: 0
outline_color: 0
border_width: 0
border_color: 0
border_side: NONE
outline_pad: 0
radius: 0
# hidden: ${Hide_Battery_Symbol}
hidden: false
widgets:
- line:
- 12, 2
- 18, 2
- 17, 2
- 17, 4
- 17, 3
- 20, 3
- 19, 3
- 19, 20
- 19, 19
- 10, 19
- 11, 19
- 11, 2
- 11, 3
- 14, 3
line_width: 2
line_rounded: false
line_color: !lambda |-
if( id(battery_soc_value) <= id(min_soc_value) ) {
return lv_color_hex(0xff0000); // red
} else {
return lv_color_hex(0x00ff00); // green
- bar:
x: 12
y: 3
height: 15
width: 6
radius: 0
min_value: 0
max_value: 100
bg_color: 0
indicator:
bg_color: !lambda |-
} else {
radius: 0
value: !lambda return id(battery_soc_value);
- label:
x: 25
y: 3
text_font: MONTSERRAT_14
text_align: CENTER
width: 35
text_color: !lambda |-
} else {
text: !lambda |-
return (to_string(static_cast<int>(id(battery_soc_value)))+"%").c_str();
- platform: adc
pin: 5
unit_of_measurement: "%"
state_class: measurement
device_class: battery
accuracy_decimals: 2 # ???
attenuation: 12db # input voltage range: 150mV --- 2450mV
samples: 16 # samples taken per update interval
filters:
- multiply: 1.72
- sliding_window_moving_average:
window_size: 15 # average over 15 values
- calibrate_linear: # linearise voltage->SOC dependency
method: exact
datapoints:
- 3.00 -> 0.0 # <=3.00V = battery empty (0.0%)
- 3.36 -> 5.0
- 3.41 -> 10.0
- 3.48 -> 20.0
- 3.52 -> 30.0
- 3.56 -> 40.0
- 3.61 -> 50.0
- 3.70 -> 60.0
- 3.79 -> 70.0
- 3.89 -> 80.0
- 4.00 -> 90.0
- 4.05 -> 100.0 # >=4.05V = battery full (100.0%)
- clamp:
min_value: 0.0
max_value: 100.0
update_interval: 4s # new value after 4s*15(=window size) = 60s!
on_value:
- lambda: id(battery_soc_value) = x;
- lvgl.widget.refresh: battery_soc_label
- lvgl.widget.refresh: battery_symbol
- lvgl.widget.refresh: battery_bar
I thought that ‘lvgl.widget.refresh: battery_bar’ should also effect the bar indicator color. Is there anything I am missing?
Jörg.
