Documentation:
Reality:
What am i doing wrong?
Yeah, thatās exactly how I was trying to use it.
Well, I had to use āflexā instead.
No, you were putting pad_column
in the wrong place. See the docs I linked to.
Above you can see a screenshot from the official documentation, my code is copied from it and only the variables are slightly changed. If there is incorrect code in this part of the documentation, it should be fixed.
Or if you are more specific about which lines in these two screenshots you see discrepancies, it will be more helpful. Thanks.
If āread the docsā is a little vague, let me break this into an easy step-by-step sequence:
pad_column
and associated parameters.pad_column
goes under the layout:
key, not directly in the widget config.I believe the screenshot you posted is from the ātips and tricksā section. This is not the main documentation, it is a set of examples that have been put together at various times and may not be up to date. If in doubt, read the primary documentation. That has had the most work put into it and has been well checked.
PRs to fix any outdated examples in the tips and tricks section (or any other part of the docs) will be welcome.
Yes, it was a tips and tricks page, and I mistakenly thought it was equivalent to the main documentation. Thank you for your help!
To avoid creating new topics, could you please advise,
I want to control the screen background.
I can change the disp_bg_image value with lvgl.update, ie substitute different image file values.
But what if I want to switch to a solid color and make the background for example black, how do I ādisableā the value of disp_bg_image , leaving only disp_bg_color?
Because if I have a color value specified, but then an image is specified, that image will be on top of the color.
For now I solved this problem by creating an āemptyā 1x1 pixel file, but perhaps there is a standard solution that I have not found.
If youāre using pages, then your work-around is probably as good as any. If not using pages, you can use styling on the background of the screen to change the image and colour opacity.
A future version using LVGL 9 will have more options for this.
Yes, iām using pages, many pages ) Building a kind of automotive dashbord for my friendās diy camper bus. Configuration with multiple devices, Ńan-bus communication, sensors, relays and a nice LVGL interface.
If you donāt mind, Iād like to ask you a couple more questions that I canāt handle with instructions.
While i have an option to change backround/wallpaper, i want to store last selected background image id with globals, to restore it on next boot.
My yaml (parts related to this problem):
globals:
- id: wallpaper
type: std::string
restore_value: yes
initial_value: '"bg_image2"'
image:
- file: "image.jpg"
type: RGB565
- file: "gears.jpg"
type: RGB565
lvgl:
disp_bg_image: !lambda 'return {id(wallpaper).c_str()};'
rows:
- buttons:
- id: bg_01
text: "Waves"
on_value:
then:
- globals.set:
value: '"bg_image1"'
- lvgl.update:
disp_bg_image: bg_image1
- buttons:
- id: bg_02
text: "Gears"
on_value:
then:
- globals.set:
- lvgl.update:
disp_bg_image: bg_image2
The problem is that on boot it tries to restore the id from the global variable, but apparently it gets an incorrect value from there, because i got black screen instead of image, and console log error
[lvgl:000]: draw_bg_img: Couldnāt read the background image (in lv_draw_sw_rect.c line #391)
I seem to be mishandling globals. Probably just misplaced some brackets or quotes) Thatās still not clear for me, could you give me some guidance? Thanks a lot!
You canāt use a string to set an image source (or any other ID) at runtime - youāll have to use some kind of map from an integer or string to an image ID. Iād suggest asking for help in the Discord #general-support channel, itās not an LVGL issue as such.
Thanks.
Am I understanding correctly that you are related to lvgl development in esphome?
What about the possibilities of animations of text and other elements besides image? If I need to create blinking text for example, would that be possible? Since Iām making an analog of a car dashboard, I need some icons to blink. And they are rendered in glyphs, not images.
