Attempts to add the integration do appear to support the leak detector at the Auth page, but the sensor never gets added to Home Assistant, and creates the following error (presumably because it only supports “Climate” sensors and not leak sensors).
Log Details (ERROR)
Logger: homeassistant.components.climate
Source: helpers/device_registry.py:129
Integration: Climate (documentation, issues)
First occurred: 10:53:08 AM (6 occurrences)
Last logged: 11:00:30 AM
Error adding entities for domain climate with platform lyric
Error while setting up lyric platform for climate
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 438, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 589, in _async_add_entity
device = device_registry.async_get_or_create(**processed_dev_info) # type: ignore[arg-type]
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 312, in async_get_or_create
connections = _normalize_connections(connections)
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 851, in _normalize_connections
return {
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 852, in <setcomp>
(key, format_mac(value)) if key == CONNECTION_NETWORK_MAC else (key, value)
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 129, in format_mac
if len(to_test) == 17 and to_test.count(":") == 5:
TypeError: object of type 'NoneType' has no len()
Do you have any update on this? I haven’t gone through your listed steps to see if anything has changed, but I thought I’d check in here and bump this thread…
I’ve got many of the Lyric water sensors I’m hoping to integrate into HA.
Same result. And the Integration page hasn’t been updated to say it supports Leak sensors.
This post is just a Feature Request, so feel free to Upvote it.
No. But someone did open a Github issue about it a few months ago, so there’s been some discussion about fixing it. But it’s not under active development.
